Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
August 24, 2026, 20:05:40
GOT PROBLEMS OR ISSUES?
PETROL
EPS
EPS
robertwiltsher
4 ·
8959
« previous
next »
Print
Pages:
1
Go Down
robertwiltsher
1st Gear
4
United Kingdom
Bristol
EPS
January 13, 2021, 08:30:32
OK - I am fully aware that I may be a bit thick here, but if the light on my dash say 'EPS Off', does that mean that it is is actually off or do I need to push the button to switch it off (and thus remove the light indication) ? Thanks !
2011 i30
Admin
Retyred @ Last
43,431
England
Re: EPS
Reply #1: January 13, 2021, 08:57:40
I think you might mean ESP - Electronic Stability Program - which helps you avoid loss of control in turns etc. It's part of the traction control system.
If you mean ESC - Electronic Stability Control - then leave it on unless you fancy hooning.
Ioniq MY2018 SE Premium Hybrid in Polar White with added oomph
robertwiltsher
1st Gear
4
United Kingdom
Bristol
Re: EPS
Reply #2: January 13, 2021, 11:37:45
Apologies - yes I did mean ESP so the question refers to that. If the light is off the ESP is on then ? Thanks
2011 i30
Admin
Retyred @ Last
43,431
England
Re: EPS
Reply #3: January 13, 2021, 12:43:11
If ESP OFF is showing, then it's switched off.
Nothing showing ∴ means it's on.
Print
Pages:
1
Go Up
PETROL
EPS
Search
Username
Password
Always stay logged in
Forgot your password?
