ABS braking problem Noise
Offline Hemanstan
      Glasgow
My 2009  I30 GRDI  Auto ABS problem , when braking get grinding noise from front, fitted new pads and ABS sensorsm but still the same, the funny thing is it only makes the noise when ABS light is out after short drive ABS comes ON  and the noise staops, ,wondering if it couild be ABS controer or brain.  any suggestions
  • I30 CDi
My 2009 has always ground when ABS has been needed most desperately. Odd but it works.
Offline Aye30
Hi, If you slow to a stop on a smooth surface, without the ABS engaging, do you feel any vibration through the steering wheel? I had an I20 and after a few years, and  I believe  a large water puddle on the passenger side, I had a warped disc. It would still brake, but it would vibrate the steering wheel while braking. Also when I replaced it the wheel nuts were a lot harder to get off on that side, probably due to the excess heat generated by the wobbly disc. When I jacked up the front wheels and gave it a spin by hand, it would slow down at the same spot.
