i30 Specs & technical details
ElleB · 6 · 1718
Offline ElleB
  • Our Elle B
HI All,
 I am trying to complete my installation of my Dash Commander data logger and display.
There are a number of parameters that I want to put into the program to achieve as good and accurate results as possible.
 I need the below....I am away on holidays and have very limited access to internet....so am limited in research capability.
I am hoping to fiddle and get the program set up while I have a few days free away from business and home, so any help will be greatly appreciated.
I was looking for :
Drag Co Eff
Frontal Area
Tyre rolling resistance co eff   (Original Kumho)
Lambda  -actual and commanded
MAF PID
MAP PID
Volumetric Eff
Final Drive ratio
Thanks all in anticipation.
Elle B
  • 2016 i30 CW auto
some of that info has been posted before,i think lorian posted it.   try doing a search.  :idea:  [in the top left of the page]
i found the frontal area , its 2.23 sq.m.   eyecon mentioned it for his g meter. is that what your using?   :winker:
 Hi Elle B ..
The one that Steve helped you with was probably the only one I would have been able to point you to.. but I will bring Trevors (surferdude) attention to this thread as he might be able to help with drag co-eff of the tyres..
Bot sure who could help with any of the others??
Hi Elle B ..
possably eyecon.  :idea: :winker:
Sorry Elle B ... Had a chat with our resident Tyre Guru and can't assist with Tyre drag Co-eff unfortunately  :blubber:
As 2i30's says a PM to eyecon might be your best source of info ... :goodjob:
