@LakesWell, i dont know about larger injectors effect other than what you said seems logical. However, what about the price? I hear injectors are extremely expensive."i'm thinking the box plugged into the common rail would be just to try to raise fuel pressure in common rail."Why would you want to change anything else? More than this implies ecu flash i think.This is only thing that is important as i see it. You have injectors working at a little higher pressure, making them cleaner and still within factory tolerance. nothing else doesnt need to be controlled. no?
What are your thoughts on free flow exhaust in context with this temp increase? Since CRDi has many silencers, catalytic converters etc they got to be strain on turbo since they are, im guessing, very restrictive in getting hot air as fast as possible out?
Nice.Well, that illegal removal is biggest crap ever invented. Last week i went for yearly insurance and technical check up and i passed eco-test without slight trouble! In fact minimum values in all fields.Well, that pretty much solves this topic :d
