, the power bills just keep climbing.
If they play with the FIT then I'll be looking at hybrid solar (and that's not a Dazz's car with a solar panel on the roof)
Maybe get outside more and not sit on the computer so much. As long as you keep coming on here With the RS232 to USB lead, it simulates a comms port so you need to go set the right port and speed on your laptop/PC in the device manager and in the client software. Won't work otherwise.Thanks Keith I'll take that into account
I've been trying to figure out why the power consumption is vast hence the research which may have got a little out of hand. The EW4008 I bought actually works great but lacks a decent logging option. That's where things started getting out of control. Using the fairly basic software supplied has actually solved the mystery of the missing kWatts. I can see the problem fairly clearly now and it turns out we do use a shedload and so now trying to figure out watt (ahem) to do about it. There's a lot of options including some open source / community projects like this one: http://openenergymonitor.org/emon/
Our daily average is 27kWh which is a fair bit for a small house. There's a steady 6-700W draw which is the fridge, stove, comms box (100W all by itself at idle) etc. I was surprised to learn my computer draws 300W when its flat out, 100W other times, more than I thought. Trying now to figure out how to cut back. Maybe get outside more and not sit on the computer so much. With the RS232 to USB lead, it simulates a comms port so you need to go set the right port and speed on your laptop/PC in the device manager and in the client software. Won't work otherwise.
