Thanks again Dazzler & db08!it certainly highlights the lines & curves of this stunning body style. See in the photo the blue i30? That's also a Premium. The photo doesn't do the car justice in White. It really shows the highlight features. They seemed to get lost in blue. Black...I have yet to see one in the flesh.Cheers,Steve
1. The HID headlamps (since it's a Premium) are set to a low, a very low spread of beam whilst driving at night on an unlighted roadway. I'm forever having to throw on the high beam to show me what's further ahead. (the 1,000,000 potholes along our crappy roads)
2. The rear door locks stay locked when the vehicle is stopped, but the engine is still running. I thought is was the child lock feature, but it is not. The internal thumb lock rocker above the handle needs to be rotated to the unlock position in order for the rear occupant to exit. I need this to be checked/confirmed.
Quote from: i30forme on July 29, 2012, 12:24:491. The HID headlamps (since it's a Premium) are set to a low, a very low spread of beam whilst driving at night on an unlighted roadway. I'm forever having to throw on the high beam to show me what's further ahead. (the 1,000,000 potholes along our crappy roads)Do you not have a "load" hight adjuster on your car so you can higher/lower beam?
Hi Steve,All my doors auto lock (which I think can be turned off) and then unlock when I stop and put it into park. There is also a switch on the door that locks/unlocks all doors so that may be your other option to unlock the rears to let people out. I see what you mean on the Sat Nav, as soon as you turn the system on it wants radio/media and you select Nav/Map. Could not see a way to turn on only the Sat Nav on the way to work, sorry 😞Can you try something for me? 😃 the button on my hatch needs to be held to open the hatch, I.e. if I just press it and release it the hatch release triggers (you can hear it) but you cannot lift the hatch (it has only half released if you know what i mean). If I press and hold and lift at the same time it opens up. Is yours the same? 😃 not sure if this is by design or if it needs adjusting. The dealer was not very helpful when I asked them to check this so my next option is to go and try one in the car yard 😉Hope the above helps a little.
