7500km Optional service
Zoltan · 6 · 2464
Offline Zoltan
      Greenslopes, QLD
  • Zoltan the Magnificent!
Hi there,
I must admit I'm not familiar with diesels and would like to change my oil (ACEA B4) and filter on my Crdi 2014 in between the 15000km.
Is there a concensus on whether there is a need to run a cleaner in the oil prior to draining or other specific procedure on diesels?
  • 2014 CRDi Premium Diesel, White
Offline cruiserfied
  • Crooked-H Hero
I personally don't encourage oil flushing but I'm referring to older engines that have sludge buildup in places.
The best way to keep an engine clean is to change oil regularly and use good quality oil and filter.
As long as you're usung a good quality, correct grade of full synthetic oil, cleaners are not necessary and most likely against the warranty conditions of the engine, so IMO no, don't do it.
Offline Just Rick
  • Big Dogs Rule
      Beverley Western Australia
  • miracles can happen
 :wts: I also choose to do the alternate services and as stated regular changing,no need for a flusher
Top quality oil and regular servicing.  :goodjob:
Optional services if required, depending on driving conditions.   :)
Offline Zoltan
      Greenslopes, QLD
That's my plan... Do the alternate services.  Cheers guys
