Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
June 05, 2024, 16:15:47
GOT PROBLEMS OR ISSUES?
PETROL
Manual Geabox gears stuck when cold
myarken
34 ·
15135
« previous
next »
Print
Pages:
1
2
1
2
Go Down
myarken
1st Gear
7
Australia
Newcastle
Re: Manual Geabox gears stuck when cold
Reply #30: April 27, 2015, 00:25:11
Thanks for all the replies.
The issue is that the clutch fluid was empty. filled up and clutch pressure kind of came back.
noticed that the fluid was instantly leaking out. Checked and it's coming from slave cyclinder.
Rang mechanic and has part on order replacing tomorrow.
Cannot use reverse at all and 4th and 5th gear. As clutch cannot reach that far to select those gears.
at this stage gearbox is fine. touch wood.
i30 07 Hatch Petrol Manual
Dazzler
Admin
Laughter is the best medicine...
67,423
Australia
Best Car Forum on the Net
Reply #31: April 27, 2015, 07:07:16
Hopefully a relatively inexpensive and easy fix!
2021 MG PHEV ( had 4 x i30 plus a Getz an Elantra and a Tucson)
Lorian
V.I.P
3,461
United Kingdom
Midlands, UK N-Line T-GDi
Reply #32: April 27, 2015, 07:59:03
After he has replaced the slave cylinder and bled the clutch normally, if he uses a pressure bleeder or the manual method its important he then bleeds the slave cylinder as it traps air. Even my local hyundai garage did not realise this. It takes 30 seconds. With the bleed pipe on the slave person a pushes and holds the clutch pedal to the floor. Person b then opens the bleed and simultaneously pulls the clutch fork all the way and then does the bleed screw up quickly. That evacuates the air trapped in the slave.
Just Rick
V.I.P
Big Dogs Rule
7,617
Australia
Beverley Western Australia
miracles can happen
Reply #33: April 27, 2015, 15:26:47
If your mechanically minded changing the slave cylinder yourself is a 45- 50 minutes job,make yourself a simple self bleeder and bleeding the slave cylinder takes a couple of minutes,save yourself a heap.
2011 SLX CRDI 6 Spd, 2010 Holden Cruze CD Diesel and 2001 Hyundai Accent Coupe
Print
Pages:
1
2
1
2
Go Up
PETROL
Search
Username
Password
Always stay logged in
Forgot your password?
