Solution to A4CF2 Automatic Gearbox Problems?
Eyethirty · 36 · 58636
Of the 2 versions, A4CF1 and 2, would the entire trans be reinforced, leaving the same VB or would A4CF2 have a new reinforced VB also
Edit: would also like to know if there's a way to determine if it's a wiring harness problem (dry solder etc) or hydraulic/solenoid
The VB failure is not specific to kms and is usually talked about by excited people who have only heard about it. So far, of all the FDs I have owned or worked on, I have never had to deal with the issue.
It seems to be caused by poor metallurgy. How do you reinforce a valve that is wearing internally? You cant!
A suspected dry joint can only be found by physically looking at the circuit.
 I am sure that dry joints are not a common fault.   :undecided: I originally made note of it here about 4 years ago. It was based upon a US U-tube claim suggesting that the VB was not at fault.
Offline blastslayer
ill just leave this here
:link: A4CF2 Tech Guide i 30.pdf
« Last Edit: February 20, 2020, 08:08:04 by blastslayer »
  • 2010 i30 sx, Auto, hatch 1.6l ...
:link: google-reader
any progress or saving the pennies  to decide which way to go?
Link doesn't work for me. Says something about expired.
Offline blastslayer
works on my end...
Anyway, with my particular fault i have made a discovery.
In D i get the occasional slip through various speeds and acceleration (throttle %) eg. travel at 60, slow to 30, re accel, slip, occasionally..  Just different things sometimes, however
in 3, this does not happen, i get no slip in 2-3, slow from 60 to 30, re accelerate, no slip, round corners stomp on gas, no slip.....in 3, no slip ever
further explanation:  In D  @ 60, slow to 30 , doesn't seem to release from D, and acceleration will ask it to go to 2nd and it wont...    Almost as if slowing down in D does not engage 3,2,1 sequentially, it just remains hi gear, and then try to accelerate and it shits.  This problem does not happen in 3.
i have concluded  in D theres not enough pressure in the valve body to run all components, (my diagosis)  Suspect the only issue is one of the valves associated with D
Working on my phone today.   :victory:
