Update currently reading 5l/100 so economy seems to do nothing but change the gears back plenty....
Hi AllFirst post ...I know this is rather an old thread, however, just thought I would add my recent experience...Received used (68000kms) i40 2016 Wagon diesel auto with DCT recently and immediately noticed the shuddering on take off. Didn't matter if it was going forward or reverse from a stand still the shuddering was evident. Seemed more pronounced when cold (engine cold not ambient cold) first thing in the morning. Once above about 25km/hr it was perfect.After no satisfactory response from first Hyudai dealer went to another who upgraded software (from DUFOD17U5S5 to DUFOD17U5S9). This altered the gear changes when going down hills to nearly elimate the uncomfortable high revs previously experienced when it decided to change down gears but made no difference to the shuddering.So, if anyone is concerned with the high revs when going down hills, maybe consider checking software version at next opportunity?If someone could post parts used to fix the shuddering it would be much appreciated. Thanks
So, nothing positive from the Dealer.Their conclusion was "characteristic of the vehicle" and referred me to owners manual with regard to operation of a DCT. Typical dealer response when the problem is probably warranty.I know they removed the hose to gain access to have a visual of the intake manifold because the hose clamp had been replaced(however, they didn't report this to me). I had cleaned it a few weeks earlier thinking it may have been engine related rather than clutch. So, obviously, they knew something wasn't right and gave up when they couldn't find a "maintenance" item to blame ...Don't know if I want to take up the fight or just get rid of the car.
So, after some discussions with a transmission repairer (who admitted limited knowledge of these DCTs as they are still considered under warranty and therefore reffered back to Hyundai if problems present) he suggested to change the DCT fluid as to elimate the cheaper options before confronting Hyundai.Oil price from Hyundai $ 150 per litre and needs 2.0 litres. Went with a Penrite option for $ 50 per 2.5 litres. The oil drained from DCT was visually clean, however, only 1.5 litres came out. When refilling, the overflow (full level indication) occured at exactly 2.0 litres. Somehow the DCT had lost 0.5 litres of oil since new?Anyhow, everything now appears to be considerably better than before with driving characteristcs about what you would expect from a DCT. I'll do another oil change in about 5000kms just to see if there is a leak somewhere and also to fully get rid of the original oil. Should any other problems occur, I'll post events .
