2009 i30 dashboard background light unstable
pcmc · 35 · 35291
  repositioning the others gave me 10.   :wacko:  Replacing the 2 missing LEDs then fully retored .......  :rolleyes:
 It no longer flickers. :idea:
 :idea: = pure arse.
Mine no longer flickers too. But..... I wait, its an intermittent fault.
To fault find a fairly complex double sided print board is labour intensive enough. To test and fault find it while it is not powered up is usually futile.
Correct procedure is ALWAYS to leave all fantasy at the door; then make some extension fly leads to give the cluster power. That way you know if the bloody thing is in fail or working mode.
Also helps to understand the circuit  :whistler: :whistler:
  :rofl:
Flicker has returned.
Flicker's lowest luminescence is same as when lights are on
Therefore no flicker with lights are on.
 :phone1: Theory Proved
Offline mc121994
    • ph Philippines
      davao philippines
can you teach me how did you disassemble the LCD?
  • first gen i30 2009
Offline mc121994
    • ph Philippines
      davao philippines
fixed !!! replaced 5 bad LEDs.. got the LEDs from the spare aircon controls...
now it lights up just like new!
« Last Edit: May 26, 2020, 09:39:28 by mc121994 »
Offline sabato64
    • it Italy
      NA
Hi, I have read all your post, even me, on my car, the display has a low brightness, before taking it apart and replacing the burnt LEDs, I would like some news about it.
On the body of the substituted LEDs, some initials are stamped that I am looking for substitutes on the internet, thank you very much.
  • Hyundai i30 2011
