Headlamp Globe Upgrades
Guest · 120 · 45562
Offline i30manUK
      England
Bob - did you encounter any issues or problems when swapping the H1's and H7's? I should be doing mine this weekend. - Will post a step-by-step photo guide!
ouri30
i30manUK,
Once I worked out how to remove the healamp units, it was a breeze.
There are 3 bolts, two at the top and one half way down.  Remove the wiring loom plug (one only).  Then it requires a litttle fiddling and the lamp unit comes away (forward).
Once out, it is a breeze to fit the globes 9much easier than any car I have owned recently.
Bob
Thanks for the reminder Bob. I too should be fitting H7 Os NBs this weekend, unless it's raining heavily that is. Sounds a doddle  :D
Offline i30manUK
      England
Thanks Bob - If it's only 3 bolts I think I've identified them already. Must say I agree with you regarding the ease of swapping - My other car is an absolute pig if you need to replace bulbs at the front - I have to remove wheel arch trim, lie on my back and cut my hand to ribbons just to change the sidelight!
Quote from: "Shambles"
It's the Wirral show this weekend so No you won't as it always rains when the show is on.
Offline i30manUK
      England
Guess what arrived today  :D  (only 24 hours after they were ordered!) They're fitted already. Here's a link to the step-by-step guide to fitting them... viewtopic.php?f=13&t=528
Offline dani
    • bg Bulgaria
      Sofia
  • First Lesson. Stick em with the pointy end.
hi
my friend with KIA C`EED installed "Xenon" system, but he doesn't like lights, because they appeared yellow.
Than he bought "Philips cool blue", but they again appeared yellow. And i think, that "Osram system" is like "Philips"
And than he found "Led lights".
This is the difference between them:
 - this is "white" Philips":
- this is "Led":
- this is the difference (Left - Philips, right - Led):
with two lights:
This is his back number:
Well eventually my order has arrived (2*H7 and 2*501).
What I'd like to know, is how much better the 501's are [brightness-wise] compared to the stock sidelights?
Too rainy to fit them here (good old UK weather) at the moment, but can I expect a significant brightness increase?
Offline Seoul-mate
      Sunshine Coast, Queensland
No....you'll still be as stupid as you always were.
Quote from: "Seoul-mate"
Hey Russ.. fancy saying that about Shambles.... :lol:  :lol:
Quote from: "dazzling_darryl"
I don't care.
Just about to go outside to fit my new bulbs, or globes as you call 'em  :)
We just got a brief respite from the rain. I reckon I've got about... 20 minutes.
I don't care.
I thought you would be as amused as me about Russ's quick retort....
More rain... It's a wonder evolution hasn't given you guys web feet  :shock:
Hehe true Dazz.
I just got one set installed. Had to stop 4 times and cover the hole, closing the bonnet too.
And now it's a bleeding torrent we got. Jeesh
Offline i30manUK
      England
Good news Shambles - god they took their time to arrive mate.
The weather forecast for today is for a few light showers - interspersed with long heavy torrential periods of rain  :lol:
...gona be windy too, so be careful with your hood up!
Just finished. They look good.
Bit of a bugger getting the offside back in - it didn't want to play. Nothing that a real good shove couldn't cure tho  :D
Oh, and that was a good tip about applying grease to the bolts, as they were very dry when I removed them
Offline Seoul-mate
No offence meant Shambles.....hope Fergie's bulbs shine long and bright,
Russ.
Hey Russ. I refer you to my previous reply...
I don't care.
:D
Finally got round to getting some better headlight globes (the catalyst was the gift voucher from Autobarn my Daughter gave me)
Decided to try the H7 (Low beam ones first) They were $50 for Philips+50% or $80 for Philips+80% (I went for the dearer ones)
From what the guys tell me I wont need to put the H1's in the High beam... I'll try and do it 2moro or Monday and let you know how it goes  :D
Does that mean your avatar will get brighter too  :lol:
:P
Put the H7 (+80%) in - you guys were right easy peasy...interesting they look like they might be made in the same German Philips factory as the originals (almost identical) hard to believe they are nearly twice as bright.. Can't wait for it to get dark (about 8.00pm these days...long dusk in Tas)
Looks like I paid through the nose for them at $80 the pair but nothing else at Autobarn for me at the moment.
Wouldn't want to pay for a replacement assemby (looks expensive  :shock: )
Sorry about the triple posting but just did 60Km return trip (the return 30 in the dark) and the +80's are great...Combined with the existing high beams quite adequate. Might go for the +50% H1's for the high beams at $40 when I need some more retail therapy just for an extra boost :P
Hey dazz - welcome to the dark side.
I mean, the bright side.
Or the light side
Well my first Nightbreaker just went on me coming home tonight :(
Have checked the offside fuse (under the bonnet, fuse number 16) and it looked ok. Swapped it with the nearside HL fuse and still nothing.
So, it looks like another pair of bulbs to be purchased :(
Hope mine last longer than that!
I need to check there's no damp in the housing as I can't see why one would blow so early in it's life. Dammed hardware. Always breaks on me
ouri30
Bad luck Shambles.  Haven't had any issues with ours (touch wood).  Was it the high or low beam?
Bob
Hi Bob. It was the offside H7 (I don't have Osrams in the hi beam)
Just waiting in now for the morning's post; should have a pair of them shortly. Hopefully the rain will take a break so I can replace the broken one
Offline Thumper
      ACT
No issues with blown bulbs here! (Chalk one up for HiD!)  :cool:
Well I changed the bulb yesterday and the filament was completely missing. Not even rolling around the bulb. Looks like it has completely vaporised  :'(
