Re active headrestsI think there is some confusion between the active headrests and the adjustable headrests in the i30. These are two different features. The Santa Fe we have (and probably other Hyundai vehicles) have active headrests, meaning that in an accident, the headrests move forward to minimize whiplash. However, the i30 we have has adjustable headreasts, but the Santa Fe does not. I'm suggesting that we have two different features here.Bob
... However, the i30 we have has adjustable headreasts, but the Santa Fe does not. I'm suggesting that we have two different features here.Bob
Quote from: ouri30 on July 10, 2009, 11:33:24... However, the i30 we have has adjustable headreasts, but the Santa Fe does not. I'm suggesting that we have two different features here.BobHiya Bob.Could there be middle ground here? Mine are adjustable and are listed as...
I like the two little prongs on the inside of the fuel filler door, so that you can rest the fuel cap without it dripping on the ducco <img src="{SMILIES_PATH}/icon_e_biggrin.gif" alt="" title="Very Happy" />
I like the fact that if you press the right hand pedel down with your foot, sometimes the car goes foward.
the opener on back of the i30cw is not a latch that needs to be pulled but a electronic button, you just press it!
Quote from: jasonw on July 11, 2009, 11:39:27 the opener on back of the i30cw is not a latch that needs to be pulled but a electronic button, you just press it!Hatch is the same mate
On the speedo there are two red lines around 30 and 50 klm phr
Quote from: Shambles on July 10, 2009, 12:00:33Quote from: ouri30 on July 10, 2009, 11:33:24... However, the i30 we have has adjustable headreasts, but the Santa Fe does not. I'm suggesting that we have two different features here.BobHiya Bob.Could there be middle ground here? Mine are adjustable and are listed as...Absolutely mate, one and the same thing I think...I just didn't know you could move them yourself !
I know mine are active headrests, but don't know if they are adjustable.. How do you adjust them? I know if I push mine to front they move, but go back than - like a spring (that's the way they work in case of an accident). And I do know how to adjust the height, but is there any else adjustment possible? Don't need it really, but anyway..
Well, I've noticed that the lighter (and the ashtray) don't have any light, although the lighter has a translucent plastic around, it's not iluminated. ..
Quote from: xpedro on July 14, 2009, 10:37:14Well, I've noticed that the lighter (and the ashtray) don't have any light, although the lighter has a translucent plastic around, it's not iluminated. ..Some models do have the illumination. My lighter & ashtray both glow in the dark when the lights are switched on
Quote from: Shambles on July 14, 2009, 10:42:11Quote from: xpedro on July 14, 2009, 10:37:14Well, I've noticed that the lighter (and the ashtray) don't have any light, although the lighter has a translucent plastic around, it's not iluminated. ..Some models do have the illumination. My lighter & ashtray both glow in the dark when the lights are switched onSo does mine
the front window dinister turns itself on for windscreen dimisting then off when the window is clear
Quote from: Mullet on August 04, 2008, 13:29:51the front window dinister turns itself on for windscreen dimisting then off when the window is clearWhen you say front Demisting, are you talking about how the air blows through the vents (with a/c) to take the mist away from the front windscreen? If so, mine doesn't seem to do this automatically. Would be handy if it did! I have to manually press the button to turn it on and off.
I think European i30's have an element in the windscreen just like we have in the rear hatch
