HOW TO - adding steering wheel volume controls!!
agentr31 · 133 · 71040
Offline Bitsumishi
  • Brisbane, Queensland
Thanks for confirming that, Ugly.
Damn. I was like a little kid waiting for the weekend to do the mod...
  • 2011 i30 SX CRDi
Offline Ugly Mongrel
  • H.O.S. inmate
No worries, mate. Hold ya horses. There are plenty of weekends left :goodjob2: :goodjob2:
Offline Bitsumishi
Heh. Well. Yes. I've pulled myself up off the floor where I was having my tantrum.
I ordered the replacement part yesterday which should arrive early next week. Then I can begin my countdown to the weekend...again.
BTW: Happy Birthday to you lot! From the interaction I've experienced thus far, this appears a very friendly and knowledgeable mob.
  • 2011 i30 SX CRDi
  • H.O.S. inmate
Good luck. Let us know how the mod goes.
« Last Edit: May 22, 2012, 23:57:02 by Ugly Mongrel »
Oh come now, you're only saying that coz it's true  :mrgreen:
Offline alc2
    • ro Romania
      Bucharest
@agentr31 : excellent  job  :D
Please more info : I would  like  to  paint in  silver the  plastic cover where the audio controls fit into . But  is  this possible  only  after the  airbag  removal and  then  remove  the  cover screws,  without  dismounting   the  steering  wheel ? I see in  the link that  you did dismounted , it is necessary in  my  case ?
Offline Bitsumishi
Yep. Go back to page one of this thread and look at the first pic again. You have to remove everything to access the screw that holds the audio control in from behind.
This pic from agentr31 shows the screw and blanking plate from behind:
http://i1218.photobucket.com/albums/dd416/agentr31/adding%20steering%20wheel%20controls%20to%20i30/SANY1492.jpg
  • 2011 i30 SX CRDi
Offline Bitsumishi
Yee-har! Audio controls added, tested and working.  :happydance: :happydance: :happydance:
I learnt a few 'traps for young players' doing this, so will post some pics and words as an adjunct to Agentr31's most excellent original how-to post.
  • 2011 i30 SX CRDi
Congrats  :goodjob: :goodjob2: :happydance:
  • H.O.S. inmate
Well done, bitsu :goodjob2:
« Last Edit: May 26, 2012, 11:39:04 by db08 »
Offline Granadino91
    • es Spain
      Spain
Hi  I mounted the Volume control on my i30 Classic but don´t work.
I read this:
 "40 - re- program your radio, consult the corresponding page of your owners manual for your stereo on how to do this!!"
How can I re-program my radio? Do I have to go to hyundai technical service for this?
Offline Bitsumishi
This posting is an addendum to the wonderful post from Agentr31 - without that original post I would not have tackled this project! Please use Agentr31’s post for FULL instructions.
Er, apologies are in order as I promised to post these pics waaaaay back in May 2012. Sorry, life got in the way...
Note: The only difference in my mod was I already had Cruise Control (RHS of wheel) so was adding Audio controls (LHS of wheel). I needed the 2L-500 cable (both audio and cruise controls), whereas if you are only installing audio controls and do not have cruise control you will need 2L-300 cable (audio controls only).
For my installation I did not need to replace the clock spring - 2011 model i30
Here is a pic of the airbag still attached to the steering wheel cover -
  • 2011 i30 SX CRDi
Offline Bitsumishi
Here’s a pic of the steering column with the airbag removed -
  • 2011 i30 SX CRDi
Offline Bitsumishi
Steering wheel removed from car with wiring disconnected -
  • 2011 i30 SX CRDi
Offline Bitsumishi
Steering wheel flipped over with back shroud removed to access wiring
  • 2011 i30 SX CRDi
Offline Bitsumishi
Offline Bitsumishi
Here’s the fitting (from rear) showing the blanking plate (refer to Agentr31’s pic 24 for front view of his fitting with audio controls fitted)
  • 2011 i30 SX CRDi
Offline Bitsumishi
Blanking plate removed - pesky little thing to remove!
  • 2011 i30 SX CRDi
Offline Bitsumishi
The lug is easily damaged, so be careful!
  • 2011 i30 SX CRDi
Thanks very much .. Excellent stuff  :goodjob2: :goodjob:
Offline Bitsumishi
Here’s the old (installed) and new (at bottom) wiring
Because already had cruise, the cable I needed was the 2L-500.
It has two connectors, one for audio & one for cruise. This cable replaces the existing single connector cable that feeds the cruise controls.
  • 2011 i30 SX CRDi
Offline Bitsumishi
Audio Controls mounted and new wiring routed.
  • 2011 i30 SX CRDi
Offline Bitsumishi
Here’s pics of the upper and lower shroud after I repaired the lugs with SuperGlue. Lots of naughty words said when I originally tried to prise them apart! (Also see pics 1-5 of Agentr31’s post)
  • 2011 i30 SX CRDi
Offline Bitsumishi
Offline Bitsumishi
Offline Bitsumishi
Here it is.... all together and working like a bloody charm! :cool: :lol: :happydance:
  • 2011 i30 SX CRDi
 :Agoodjob: :Drive:
