Great job!What did you use to tap into the fuse? It looks like the wire is protruding from the top of the fuse; I've only seen low-profile mini fuse taps with the wire sticking out from the side.
Quote from: tla on April 07, 2014, 12:01:35Great job!What did you use to tap into the fuse? It looks like the wire is protruding from the top of the fuse; I've only seen low-profile mini fuse taps with the wire sticking out from the side.I followed martybrisbania's guide on page 2 in this thread. Did what he did in step 11. It's one of those wire tap mini blade fuse 10A i got from ebay. I think there's many ways to connect the fuse to, but this way allows the DRL to turn on only when engine is running/key turned to ignition on and turns off when engine is off.
Ahh i think i know what you mean, yea I think it does, as you can see it connects fine and it's not loose or anything, just protruding abit at the top. I think the metal contacts springs keeps it in place by holding it in.
The wire tap fuse and control relay have now arrived and look OK.I've tried the fuse in the fuse box and it fits fine. I've also connected the relay up to the battery and checked it out and that works fine too.Just got to get the car off my wife and connect everything up. Not long now.
I contacted my Hyundai dealer today they quoted me $160 per fog light.
The cheapest I can find them on eBay is about $300 ish
That's them fitted and working! I saw and i30 Station Wagon when I was driving home tonight and it had them fitted as standard and they looked just like the ones I've fitted to our hatch which is good.Here's a few pics:The relay is on the wing next to the fuse box.Here's a close up view.Job done!
