Philips LED DRL.
Offline constipated
I was wondering if anyone with a bit more electrical experience than me could advise.
How would these possibly go with the i30?
http://www.invisionsales.com/lighting/philips/drl/drl-daylight-4
The installation instructions are here:
http://www.invisionsales.com/lighting/pdfs/led_daylight_4_installation_guide.pdf
Most of the installation I get except the actual connection to the existing headlight wiring. What does the "one touch connector" do and what is involved in connecting it to the existing wiring.
How easy would it be to do?
Looks quite easy.
The "one touch connector" is simply a snaplock, which bites its own way into existing wiring without the need to splice or cut.
How easy, depends on your confidence. My problem would be getting the things attached at the right height & width to adhere to our EEC regulations.
Now that is a mod I would consider for both our cars if not too expensive .. I would do it to the Hybrid first so Trish could see if she liked the look... :goodjob:
Offline constipated
Looks quite easy.
It does give you measurement to ensure you are attaching appropriately.
Back to the connection, in the site's video + installation guideline, it states you have to identify the parking light electricity supply cable. Would there only be one, I thought there'd be a positive and negative cable.
It also states you find out which one is correct by disconnecting it from the headlight plug, sticking the orange wire from the the control box into different sockets within the plug and an LED on the box lights up if it is powered.
Are all headlight assembly plugs the same, ie it's  a standard connection.
I take it you just work backwards and it's logical depending on which hole in the plug  you've discovered as active, you work backwards and identify the appropriate cable supplying that hole.
Lastly, those snaplock connectors, are they able to connect to the cable at any part of its length?
Offline constipated
Dazzler,
with the current state of the dollar against the pound, Powerbulbs would have it at about $150 for the LED daylight 4 if it was self installed. Free delivery to Oz.
How does that sound? I guess you're paying for a premium product compared to Ebay stuff.
Pretty sure wiring these DRL's into the parking light wiring won't be legal in Australia as headlights and parking lights need to be OFF when daytime running lights are ON....   :fum:
Dazzler,
So that is for a pair? or each? (for a pair that is not bad...)  :goodjob:
Offline constipated
That's the beauty of it Rusty. They are hardwired on, but use the current in the parking light wire to feed to the control box to SWITCH OFF when parking light or headlights are on.
This means they should be road legal.
Offline druggist
  • magunuthVE
    • pn Pitcairn
      Usa
  • Hyundai i30 SX CRDi 1.6 manual CW 2010 MY11
Be interested in seeing where you could fit them as I have been thinking of doing the same.
Ok, ta...I downloaded the instructions and now understand how they get around it...cheers  :)
Personally I'm not a fan of them but I guess we won't have a choice soon the way things are heading....  :undecided:
Found them a bit cheaper on eBay.... :goodjob:
http://www.ebay.com.au/itm/PHILIPS-LED-Daylight-4-Philips-LUXEON-LED-Safety-DRL-4-/360378816399?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53e840578f
In the UK - Halfords and others sell a similar product branded by Ring Automotive at a much lower cost.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_categoryId_165688_productId_787887_langId_-1?cm_mmc=Shopping-_-Google%20Product%20Search-_-Lighting-_-Ring%208%20x%20LED%20Daytime%20Running%20Lights&source=shopping#dtab
You can download the fitting instructions and wiring diagram here  http://www.halfords.com/wcsstore/libraries/document/242292.pdf
I am no electrician and I am mystified at how the control unit knows when the engine is running to switch the lights on.
The feed comes direct from the battery which gives me the impression the running lights will be on permanently until the control unit senses that the car side lights are on and then switches the running lights off. However - the bumf states that the running lights come on only when the engine is started and are switched off when the car's side lights are on or when the engine is not running. Can anyone explain how this is done in simple terms.
It says to connect the white wire to an "ignition supplied source"... I would take that to mean a feed that becomes live when the key is turned; confirmed by their phrase "ignition switched source". Job done
Offline Keith
      Telford, Shropshire, England.
 :lol: Hello members... I used to be on here username Ffoxy but as my car has behaved perfectly I haven't been on for ages & my old log-on wont work anymore so here I am again! I know this is an OLD old Thread but...
I have fitted some L.E.D. string DR L's. I have a relay that will switch the DR L's off when I switch the side / headlights on in line with UK legislation.
But what I am after, from you knowledgeable folks... is :-
My i30 is a 1.6 petrol Premium, all I need now is an ignition switched 12volt +ve supply from under the bonnet so the DR L's come on when the ignition is on, I don't want a switch inside & I don't want to run a 12 volt supply from the cabin, so... anyone know where I can pick up that 12 volt ignition switched supply? And which wire supplies 12 volts to my sidelights at the front so the relay will handle the switching off?
Cheers in anticipation all  :cool:
:lol: Hello members... I used to be on here username Ffoxy but as my car has behaved perfectly I haven't been on for ages & my old log-on wont work anymore so here I am again! ...
Naughty boy. You could have requested a password reminder, or flagged it on Facebook :rolleyes:
Quote from: Rules
I. User Names:
...  Members creating multiple user names without a prior agreement with Admin or Moderators will be permanently banned from the site.
Offline Keith
 :( Sorry Steve... can that be corrected now & I'll be good I promise, I'd prefer my old Profile TBH.
as sly as a fox.  :lol: :rofl: :rofl:
Offline Keith
 :-[ I know.... but all sorted now, no malice aforethort...  :blubber:
I'm laughing with you,not at you.  :mrgreen: :rofl:
Offline Keith
And taken that way fo sho!  :goodjob2:
you could hook into the cigarette lighter wiring to get power,that power turns off and on with the ignition.  :idea:
Offline tla
Use a couple of piggy-back fuses, like this http://www.parts-express.com/pe/showdetl.cfm?Partnumber=071-585
Use one piggyback fuse on the B/UP fuse for a source which is hot when the key is in the ON or START positions.
Use the other piggyback fuse on either the H/LP LO LH or H/LP LO RH fuses for a source which is hot when the head lamps are on.
Make sure the piggyback fuses are in the right direction.  Also, it might be a little tight for space in the fuse box.
I looked into fitting DRL's to my i30. I dropped the idea because the styling of the front of the car does not lend itself to the addition of DRL's without them looking like an ugly add-on if installed in a position that satisfies the legal requirements.
In the UK the lamps should be positioned symmetrically and in pairs; the same height from the road and the same distance from the sides of the vehicle.
The lamps should be fitted so that their outer edges are no more than 400mm from the outer edge of the vehicle. Height above the ground must be a minimum of 250mm and a maximum of 1500mm.
This means that on the current i30 the lamps will have to be mounted on the surface and stick out on front of the bodywork - there just isn't a suitable recess to tuck them into. The alternative is to carry out surgery on the plastic front bumper and cut some slots to accommodate them - something I was not prepared to do.
Offline Keith
String l.e.d.'s were my choice for that reason Alan, rather than the horrid block built things places like Halfords sell.
Have you bought the new version then as per your avatar?
I utilised the "brow" above the foglights, attached my string under there. Unobtrusive & meets all the height / width / symmetry conditions.
Offline Keith
 :goodjob: Agreed, so is the audio feed, but without knowing where under the bonnet the feeds are, it means running a wire into the cabin & I dont want to do that.
Offline Keith
Thanks TLA, I'll look at that  :cool:
The only string lights I have seen (so far) are not really bright enough to be classed as "proper" and functional DRL's. They are visible at night but not so much in daylight. More like the string Christmas lights you can get.  I guess that the brighter LED's require a certain depth to function.
Regarding your question - The new 2012 i30 is not yet on sale in the UK - my birthday is in March - so I might treat myself subject to seeing it in the flesh and taking a long test drive. It will need to be a lot quieter and more economical to get me to change.
Offline Keith
Mine were £1.99 from E-Bay & in broad daylight make my headlamps & foglights look yellow!  :scared:
I read in another topic that there is a DRL fuse in the engine bay. Check out it's off / on logic. All the logical switching may have already been done for you and the correct fuse would be protecting the correct circuit.
PS  Use a TEST LAMP to check the fuse logic.  :neutral:
