Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
August 25, 2026, 06:19:02
GOT PROBLEMS OR ISSUES?
GENERAL
Gearbox/clutch
Gearbox/clutch
Npmr
12 ·
3870
« previous
next »
Print
Pages:
1
Go Down
Npmr
2nd Gear
46
Gearbox/clutch
August 09, 2011, 15:51:13
Another query from a slightly nervous new owner! I have searched for this problem but not really found anything relevant so would appreciate the views of knowledgeable forum members.
I have only driven 400 miles from new in my i30 (1.4l petrol manual) I have struggled to shift the gear stick into 1st gear when stationary a couple of times at junctions, meeting strong resistance despite engaging the clutch. I have then had to put the car into neutral to successfully engage 1st gear.
The car’s handbook refers to this procedure if there is difficulty with engaging reverse gear or first gear so I am assuming that it is already a known issue.
Have any other forum members encountered this issue and if so have you had anything repaired or changed on the car to sort it out? Could it improve over time as the car is run in?
Thanks again for your advice.
StarSeeker
4th Gear
351
United Kingdom
Midlands UK
1.4 Comfort in Midlands UK
Re: Gearbox/clutch
Reply #1: August 09, 2011, 16:07:41
I had the same problem with mine in first and second gear but eased with use. I personally would give it a bit more time to bed in, as long as it aint crunching.
bumpkin
Top Gear
Keeping it in the family!
8,022
Scotland
Aberdeen
Re: Gearbox/clutch
Reply #2: August 09, 2011, 16:08:15
It will improve over time, try maintaining a little forward pressure on the stick and lifting the clutch pedal a bit, there will be a point when the synchro will meet up and she will slide in easily (be ready to dip the clutch again though
Kia Sportage 3, 1.7 CRDi EcoDynamics
eye30
Global Moderator
HOS BOSS
27,423
England
Wirral, UK. - 1.4 Petrol Active - Aqua Blue
Re: Gearbox/clutch
Reply #3: August 09, 2011, 17:44:57
If you can persevere until 1000 miles as the dealers seem to suggest this is a mileage to allow the bits and bobs to bed in but if you are still not happy take it back to the dealer to have a look at it.
The cables may need slight adjustment or even a change of gearbox oil to a lighter oil as the cooler weather will compound the issue until the engine/oil warms up.
You would have thought that by now this would be an issue of the past
1.4 Petrol Active I'm no expert, so please correct me if
Admin
Retyred @ Last
43,431
England
Re: Gearbox/clutch
Reply #4: August 09, 2011, 18:56:46
As above - the way the gears are linked to the gearknob by cable probably means they are issued tightly strung from the factory. I know my 1st/2nd selection was tough to start with, but it does ease up.
Funnily enough, at my latest service the dealership must have decided my gear selection was too easy, so they tightened it all up, despite denying it
Ioniq MY2018 SE Premium Hybrid in Polar White with added oomph
asathorny
Top Gear
Wonky Donkey
6,635
England
Curmudgeon
Re: Gearbox/clutch
Reply #5: August 09, 2011, 19:10:50
It'll improve as it gets better......
The Lancashire Lad
Admin
Retyred @ Last
43,431
England
Re: Gearbox/clutch
Reply #6: August 09, 2011, 20:50:39
Quote from: asathorny on August 09, 2011, 19:10:50
.. and as it gets older too
Dazzler
Admin
Laughter is the best medicine...
67,423
Australia
Best Car Forum on the Net
Re: Gearbox/clutch
Reply #7: August 09, 2011, 23:23:50
That is interesting as the latest batch of I30's over here (Korean Made) have absolutely brilliant gear changes in every gear .. (Trish's 5 speed CW -MY11 model) is amazing...
2021 MG PHEV ( had 4 x i30 plus a Getz an Elantra and a Tucson)
bfc_xxx
2nd Gear
51
Greece
Re: Gearbox/clutch
Reply #8: August 15, 2011, 18:13:38
I had the same problem when i had 2nd gear and I needed to engage 1st.
The gears behaved better after some time. After 6000km problem dissapeared.
Npmr
2nd Gear
46
Re: Gearbox/clutch
Reply #9: August 16, 2011, 06:55:59
Thanks to all for your comments and advice which generally suggests the problem I am having is not unusual and should ease over time.
I have driven 200 miles since my initial post and generally the gearbox has felt ok. I have had one incident when I have not been able to get into first without reengaging neutral and 3 or 4 stiff changes where I have had to push the gear stick firmly into first.
I will see how it goes for the next few hundred miles to see if the gearbox 'smooths out' any more. I don't think it would be acceptable for a new car to have this problem over the longer term.
StarSeeker
4th Gear
351
United Kingdom
Midlands UK
Re: Gearbox/clutch
Reply #10: August 16, 2011, 10:01:16
You never mentioned what types of roads you mainly drive on, so if you are driving on roads that do not require a lot of gear changes, the gearbox will probably take a lot longer to bed in
Npmr
2nd Gear
46
Re: Gearbox/clutch
Reply #11: August 16, 2011, 20:29:27
I drive a fairly mixed route about 50 miles town and country, hill and dale each day. The car is good fun to drive on this route barring the worry about not being able to get into first gear every now and again! A fair amount of stop/starts and gear changing.
Print
Pages:
1
Go Up
GENERAL
Gearbox/clutch
Search
Username
Password
Always stay logged in
Forgot your password?
