Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
May 23, 2024, 21:00:27
GENERAL STUFF
GENERAL DISCUSSIONS
Random Chit Chat
US Module
US Module
icey_niels
10 ·
2115
« previous
next »
Print
Pages:
1
Go Down
icey_niels
2nd Gear
18
Belgium
Kwaadmechelen
US Module
October 21, 2011, 19:35:39
I want to put an US-module inside my car but,
I need to find the wire that powers the turn-signals. It has to be as close to the headlights.
Does anyone know which one??
tnxx
Dazzler
Admin
Laughter is the best medicine...
67,423
Australia
Best Car Forum on the Net
Re: US Module
Reply #1: October 21, 2011, 21:31:43
Can't help with your query but can you explain the purpose of a US Module.
From a quick Google and a look at a couple of Youtube vids it appears to give you more control over the Turn signals? Turn them all on at once, turn them up or down in brightness and make them flash like a Hazard Flasher does?
2021 MG PHEV ( had 4 x i30 plus a Getz an Elantra and a Tucson)
icey_niels
2nd Gear
18
Belgium
Kwaadmechelen
Re: US Module
Reply #2: October 21, 2011, 22:34:01
a US Module is an electric relay that makes your turninglights burn constantly for 30%, and when you turn on for example the left one.
The lamp burn 100% -> 30% -> 100% and so on.
I need the wires from the turninglights, i have to cut them threw an connect the module between the wires.
Problem is that the wires aren't connected separetly but on 1 connector to the lampunit.
Phil №❶
Top Gear
Loco, most of the time!
21,976
Australia
Re: US Module
Reply #3: October 21, 2011, 22:44:16
The only way I can think of without having a reference manual handy, would be to remove all other bulbs except the turning lights and then use a multimeter to see which wire(s) are conducting to earth. Use the OHMS setting & there should be a measure of resistance which would be the bulb filament. If it's 0 then you're grounding directly to earth, which would be a bad thing. This device is illegal in Australia, the cops would have a field day if you tried that over here.
2008 SX CRDi Auto White (Lila)[hr]2010 SLX CRDi Auto Red (Ruby)
icey_niels
2nd Gear
18
Belgium
Kwaadmechelen
Re: US Module
Reply #4: October 21, 2011, 22:49:32
This could be a ggod solution if i could use such devices
i'm not that good with measuring wires.
I"ll give a try tomorrow
@847563: Here is Belgium it's also illegal but i'm planning on using a button for switching it on and off.
Phil №❶
Top Gear
21,976
Australia
Re: US Module
Reply #5: October 21, 2011, 22:55:08
Do you have a friend who might know how to use a multimeter. Otherwise you will need an auto electrician. It is not a good idea to do this in modern cars unless you have good knowledge of electrical wiring. You could damage other components, like the ECU, fuses, flasher device etc.
May I ask why you want to do this.
icey_niels
2nd Gear
18
Belgium
Kwaadmechelen
Re: US Module
Reply #6: October 21, 2011, 23:02:56
I got the same thing on my last car and i looks great.
it's more a wanne have thing, some people buy angel eyes, some use daylight-leds and i want a us module
It's a good idea to get a friend
Phil №❶
Top Gear
21,976
Australia
Re: US Module
Reply #7: October 21, 2011, 23:05:14
Good luck with that.
Can you put your country flag on your profile so we know where you are from.
Admin
Retyred @ Last
43,337
England
Re: US Module
Reply #8: October 21, 2011, 23:13:08
I've still no idea what a US module is needed for.
You Belgians are so wacky
Ioniq MY2018 SE Premium Hybrid in Polar White with added oomph
Phil №❶
Top Gear
21,976
Australia
Re: US Module
Reply #9: October 21, 2011, 23:30:10
shambles
II guess there isn't any NEED for it, but I have previously seen this function in some US movies. Often wondered why different countries adopt different standards, who knows.
Print
Pages:
1
Go Up
GENERAL STUFF
GENERAL DISCUSSIONS
Random Chit Chat
US Module
Search
Username
Password
Always stay logged in
Forgot your password?
