Help with pulling Headlight Assembly apart
Dazzler · 26 · 9407
New Member Dima (from Russia) has asked for help with pulling his i30 headlights apart (without breaking them)
I am guessing they are the newer ones with the Dark refectors which are apparently even harder to separate..
So what is the goss.. anyone successfully parted and put them back together.. What are the tricks?
I think I recall the chap who put the angel eyes on his car recently said that type can't be opened.  :'(
Offline Dima
    • ru Russian Federation
can be cut glass and then put another? or plastic and then throw them back?
you need a good heat gun,it softens the glue so you can pull them apart.  :winker: thumper did his by putting them in his oven on a low heat.  :Shocked: :scared:  i hope this helps you out.  :mrgreen: :goodjob2: :goodjob:
Offline Dima
so who ever tried it?)) and then in the oven, I melted the entire headlamp :razz:
Offline Dima
and may you have to disassemble only glass on the front headlight? I used just replaced them and all
I think it might be best to leave them as they are Dima.. If you haven't already destroyed them (it appears they aren't designed to be parted)  :undecided:
i was going to paint my lights black inside but changed my mind because of haw hard it is to pull them apart.  :disapp: at $350 each it could be a costly mistake.  :faint: :idea:
Offline Dima
bad  :disapp:(((I've already bought, even to her angelic eyes .. but not with restyled headlights I30 do not go? like to find a battered her to buy a separate lights and then attach themselves
that's what i have been thinking of doing.  :goodjob2:  keep the good ones for spares.  :mrgreen:
Offline Dima
We are just a few of these machines and no headlights on the disassembly of these (Can you there where you can not b beaten with restyled headlights or rent such a pure glass these?
Dima, Your Translations are hard to understand. You may need to get Russian Member "meehalych" to help translate if he doesn't mind... :whistler:
Offline Dima
)))))))) I mean, you can find a battered car and with her ​​headlights off?)
Most battered cars would have battered headlights I imagine  :winker:
It appears the silver reflector lights MAY have been SLIGHTLY easier to open but you would still have to be very careful not to damage them.. :confused:
What if it got battered from behind  :whistler: They'd still be ok.
Offline meehalych
  • Aircraft technician
      Kolpino
 :mrgreen:
Offline Dima
Called today with the same service, bought a new device is for posting headlamps'll take tomorrow for another attempt
sorry for my English)) It s GOOGLE)
that's a bit kinky.  :twisted: :rofl: :rofl:
Offline Dima
and how much does the lights costs at the official dealer? cat can be taken apart?
In Australia I think they are A$300-$400 each.. But still no guarantee than can be separated...
I'd be doing some other modification (there are plenty of others to choose)
Offline syecadelic
Me possibly  :D
Allow me to introduce myself (= Sye/Syecadelic/Simon/You there,
https://i30ownersclub.com/forum/index.php?topic=7021.msg108190#msg108190
You can't separate the new (facelift type) model. A completely different glue is used, possibly of better strong quality to prevent in the off chance condensation inside the unit
Even sharkracing, who have done many over the years couldn't succeed, you can actually see where the join of the lense has started to melt in their attempts.
If you can get hold of an original (all chrome) set then its a matter of running a heat gun round the seal and voila. eBay should source you a set easy enough, make sure its the correct unit for your country, (left hand drive I presume?) as the beam pattern will differ from the other side. :)
Hope this helps, any other help just ask :)
  • Premium 1.6 CRDi 2008 MY
Thanks very much Simon  :goodjob: I have PM'd Dima to bring your reply to his attention  :D
Yeah, thanks Sye. BTW those angel eyes are really impressive.  :goodjob2:
Offline syecadelic
Cheers guys,
even until this day i love them, I think it was the fact I put so much work into them.
I have an old spare set, without the angel eyes, i want to separate again and maybe colour code the 'now black' with the red of the car, to see how it looks.
seen a ferarri with it done, and it looked awesome.. but then again it was a ferarri.
Ferarri, i30,,,,,,,,,,,, so what!  :Drive:
