USB port and SDVC
middy · 13 · 4594
Offline middy
  • White i30 SLX CRDi, 5sp man. Brisbane, QLD
I was just reading the owner's manual and it has a warning not to start the car with a USB stick plugged in just in case static electricity destroys it.    Does anyone leave them plugged in all the time?  It sounds to me like a warning just in case the one in a million chance happens and your USB stick gets fried (a bit like labelling all chocolate bars 'may contain traces of nuts' just to cover themselves even though there are no nuts in it).
Another question.  In the owner's manual, the section covering the audio mentions an SDVC option in the setup menu but it doesn't state anywhere what it is for.  In the option you can turn it on or off.  What is it and do I want it on or off??
ouri30
middy,
Leave our USB in all the time (16Gb) and never had an issue.
SDVC is speed dependant volume control.  Somewhere on heare there is more about it.  It is supposed to increase and decrease the volume of the stereo related to the speed of the vehicle.  Do a search for SDVC and you should find it.
Bob
Offline middy
Thanks for that.  Duh!  I should have searched the forum first shouldn't I?  As for the USB stick I might try leaving mine in because it would be a pain to have to keep remembering to remove it every time I start the car.  I will also have to buy a larger memory stick as the 512 MB one that came with the car probably won't hold much.
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
Mine is left in all the time, although I do tend to listen to radio mostly so the stick is not generally being read during start-up and switch off.
I would guess that starting the car is probably the point where damage is most likely to occur due to the stick getting power on ACC then draining as the power is diverted to start the car.
My tuppence anyway
Brian
I leave mine in all the time, except for updates  :?
Offline ozsnowman
      Central Victoria
Mine stays plugged in and on USB all the time, and never had a quibble with it!
Offline LuciferDarklord
      Bindoon, W.A.
  • Bindoon, Western Australia.
Yep, leave mine in all the time unless my phone needs charging (i dont have a cigarette lighter charger but I have a USB cable that charges the phone)
bez10y
Mine is left in.
Aside from being a sysadmin I am also a part electronics engineer, and the USB system in the i30 SHOULD have the standard power surge protection built in. They warning is something that you'll find is there for those rare occasions that power surges may get through.
One more benefit of a forum such as this - our wide ranging expertise   8-)
That's good to know bez10y
Offline L30N
      Wallsend, North Tyneside, UK
  • Wallsend, UK
I always wondered what the SDVC setting was for. Fantastic! Now when my partner is talking loudly I can turn the volume up and say "that's the SDVC kicking in".  :)
bez10y
Quote from: "L30N"
I always wondered what the SDVC setting was for. Fantastic! Now when my partner is talking loudly I can turn the volume up and say "that's the SDVC kicking in".  ;)
Offline tiny
    • ro Romania
      Bucharest
from my experience: I had a cheap usb once, it got....f*ck3d up, probably because it was a no name
since then i have been using an 8GB corsais voyager, it's great and had no problems what so ever! i never turn of the stereo,i have been trying to do so but i forget quite often.
Offline Duke750
      Buderim
I leave my 30GB iPod Classic in all of the time. Turns itself ON sometimes, but I haven't had a lot of problems. If anything happens I can just reset the iPot and reload 25GB music...
