Engine shutdown on low speed or at lights
Josef · 13 · 4177
Offline Josef
    • il Israel
      Israel
Hi All, my i30 PRIMUME has an intrmitent problem: from time to time engine shutdown while driving in low speed, it also happen when waiting on lights.
Other signatures happen the same time:
1. ESP OFF yellow light turn on
2. When trying to re-ignite there are few options that happen:
    a. in most cases - can not ignite on first try, car is shaking, eventually it ignites but ESP OFF light still on   and car is faltering while driving. I nust stop and re ignite
    b. Some time can re-ignite immediattely and normally.
 Another info: before ignation I have to dial code number.
Do you have an experiance with such problem, what was the diagnostic and the fix?
Josef
« Last Edit: December 21, 2011, 09:30:24 by Josef »
Welcome to the forum Josef,
Can you tell us your car type diesel / petrol, auto / manual  & what country you're in.  :neutral:
Welcome Josef (from Israel) I'm guessing it is a petrol they are much easier to stall... :winker:
Offline syecadelic
Josef
What do you mean by dial a code?
Also sounds like it could be the crank sensor is starting to go, when you say 'Low Speed' your revs are dropping, possibly below X amount. If you slow down but keep revs up this could help prove my point. (Put it in neutral before lights, and keep the revs up, to save clutch?)
Alternatively it could be another sensor.
Also welcome
  • Premium 1.6 CRDi 2008 MY
Dazz
Can't see the word stall in the original text, so could still be an auto.
Alternatly you could ask the dealership to have a look ????   Just a thought  :Shocked: :Shocked: :Shocked: :Shocked: :Shocked:
Offline syecadelic
Thats just too obvious :razz:
Hi Josef
Welcome to the club; if you have the tools, make sure the battery leads are fixed tightly.
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
Josef, it would be better to reply to the comments in the thread rather than reporting them to us as only the admin and moderators see the reports.  Thanks! :goodjob:
Offline syecadelic
I don't like being reported :(
Can the mods help in regards to were Josef is from? I assume Europe somewhere?
Click his "avatar" to view his profile :P (tho Dazzler did mention it in passing ;))
Offline syecadelic
Apologies, Steve, must have been half sleeping :(
Not to sure on the Hyundai front over  in Israel. :(
