so is this something I can do my self ? and paint the inside of the headlight ?
It might pay to see if you can pick up a second hand set and do the work on those, carefully and at your leisure. Then just swap them over when you're satified and sell off the others or keep as spares.That way, you're not under the pump time-wise and you can take your time and do a good job.
Quote from: db08 on May 17, 2012, 09:22:03It might pay to see if you can pick up a second hand set and do the work on those, carefully and at your leisure. Then just swap them over when you're satified and sell off the others or keep as spares.That way, you're not under the pump time-wise and you can take your time and do a good job.Great idea Dave (Very enlightening)
Quote from: Dazzler on May 17, 2012, 10:42:49Quote from: db08 on May 17, 2012, 09:22:03It might pay to see if you can pick up a second hand set and do the work on those, carefully and at your leisure. Then just swap them over when you're satified and sell off the others or keep as spares.That way, you're not under the pump time-wise and you can take your time and do a good job.Great idea Dave (Very enlightening) Should give him time to reflect on how best to do it.
Quote from: surferdude on May 17, 2012, 10:49:23Quote from: Dazzler on May 17, 2012, 10:42:49Quote from: db08 on May 17, 2012, 09:22:03It might pay to see if you can pick up a second hand set and do the work on those, carefully and at your leisure. Then just swap them over when you're satified and sell off the others or keep as spares.That way, you're not under the pump time-wise and you can take your time and do a good job.Great idea Dave (Very enlightening) Should give him time to reflect on how best to do it. He might even win a Golden Globe Award.
Might be a bit scary if you, Dazz and me ever get together over a few beers.
Quote from: surferdude on May 17, 2012, 11:05:20Might be a bit scary if you, Dazz and me ever get together over a few beers. Sure would
Very Nice Glacius cant wait to see them on
Nice pics Have you fitted a non standard radio aerial
