I would recommend disconnectning any extra devices in the cig lighter and see if that stops the interference. Try with the engine off and then on to see if it comes from the engine / alternator. It could just be that the station signal is not strong enough. A wiring fault that could damage the radio would normally blow a fuse.
I can't download the samples as our webfilter says the fileden site is p2p and possibly hosts porn
Shambles try this:Sample 1:http://www.zshare.net/download/99405101d46ea47a/Sample 2:http://www.zshare.net/download/9940510339a4a4b9/
I have listened to both examples. The noises do not sound like interference from the engine to me. Rather, it sounds like the radio is not tuned exactly to the station frequency. Perhaps retuning may help. There are other considerations I would mention though.1. AM band is bad for picking up electromagnetic interference from power lines, engines etc, unfortunately, that is a characteristic of this type of radio wave.2. In Australia, AM is transmitted from 540 KHz to 1600 KHz approx. The higher the frequency, the weaker the radio. Notice the ABC grab the best end of the AM band, the lower frequencies. This is because the lower frequencies are able to penetrate walls and obstacles better than high frequencies, which tend to be reflected rather than penetrate. That's why TV is hard to receive in a car.3. Number 7 sounds like the station is being swamped by another more powerful signal, possibly from a closer transmitter. Number 6 sounds very much like shortwave scrambler interference which is an entirely different band altogether.As the tuning in these radios is electronic and very accurate, (so FM stations can be tuned accurately), I can only suggest that if retuning doesn't help, then back to the dealer I'm afraid. I am not familiar with the tuning procedure becaule I've never need to but if you can tune a radio station manually, make sure you store the station's frequency exactly otherwise you will be storing it off station with the same results you currently have. I hope you can understand what I'm trying to say.
Quote from: constipated on March 16, 2012, 11:25:34Shambles try this:Sample 1:http://www.zshare.net/download/99405101d46ea47a/Sample 2:http://www.zshare.net/download/9940510339a4a4b9/Nah, same thing. I'm behind HP's very strict blue coat webfilters
Shambles,Could you accept them as attachments in an email.
What would alternator related interference sound like? Is it common?
Brought the car back to the dealer to demonstrate the interference. Met the foreman who seemed to recognise the problem. End result will be another radio. He seemed to state that it seems to be a specific problem with the "noise suppressors" within the radio and 873 kHz which corresponds to one of the most popular AM stations in Sydney.Apparently Hyundai are aware of this problem but unfortunately some of the radios which are meant to be fixed of this issue are coming back still with this issue, hence why a new radio did not fix it for me.Have to cross my fingers for another radio without this issue.In this instance the dealership was very helpful.
Might have to take mine in then. Very obvious at 882 kHz and only slightly less so on 693 kHz which are the two stations I prefer to listen to.
Guys... I get this on 693Khz here in the UK in the Midlands, radio 5 Live for the UK members lol!There is an alternative frequency for 5 Live for Northern folks, 909Khz... I get this crackle over eneven surfaces on that frequency too...I can make it happen by hitting the dash with an open hand above the radio.It doesnt happen on F.M, just A.M.I took the radio out and gave the aerial connector a good clean with a proprietry Switch cleaner and it vanished for over a year... it's back now... so I need to do it again or find an alternative way of connecting aerial to radio.Try it and see... its a no cost option and took me about 20 mins to do.
