My new DOD F500LHD
Shambles · 87 · 25846
Can you lot keep the noise down please?
I'm trying to play with my new Doddie :D
Offline meehalych
  • Aircraft technician
    • ru Russian Federation
      Kolpino
Congratulations with your new camcorder.
If you have any questions about settings - ask.
I didn't have that small strap  :undecided:
Good one Steve..  :goodjob: I appear to have lost part of my charger for our BENQ M1 Video Camera while on our trip..  :confused: I might have to retrace my steps..  :sweating: (That is what my Mum always told me to do)  :Shocked:
Misha - I don't need that strap so I shall send it to you. With your postal system, you should receive it sometime in 2014 ;)
I've packed it all away now until I get home, but I couldn't see an easy way of clipping it to the windscreen without hiding the viewing screen, unless I use the tripod screw connector with my existing windscreen mount, which I probably will anyway.
This thing seems to have a 12mp resolution at 60fps, not the 5mp/50fps I was expecting :eek:
I'll play some more when I get back.
Offline meehalych
      Kolpino
No, thank you, I'd rather come and pick it up myself  :)
How is your DOD fastened to your windscreen Misha? Do you use one of the fasteners that came with the camera?
Offline meehalych
      Kolpino
Yes I do.
I use this set
Thanks Misha. I think I'll use the screw/tripod mount with my existing holder - it's all metallic and looks a bit better :)
You might have to ask the old handyman guy next door to come and put it together  :lol:
Will be good when all done - I'm watching this one with interest.  :goodjob2:
Well I've had a play and driven to work today using it.
I'll post some clips when I get time but I'll need to edit them down. I've set it to create 10 minute clips and each clip is 500mb in size :eek:
But the quality is amazing  :Shocked:
I have a question for anyone who has a similar device... there are two maximum resolution settings "1920x1080" and "1920x1080 S". Any idea what the "S" means? My drive in was set at "1920x1080 S" but I've changed it to "1980x1080" to see what the difference is later.
Also, what does your menu system look like?
This or this
I like the look of this so far  :goodjob:
Offline meehalych
      Kolpino
Offline meehalych
      Kolpino
I have a question for anyone who has a similar device... there are two maximum resolution settings "1920x1080" and "1920x1080 S". Any idea what the "S" means? My drive in was set at "1920x1080 S" but I've changed it to "1920x1080" to see what the difference is later.
I've read something about it in one of the Russian forum, but as I don't have it I didn't pay much attention, but I could try to find it
Thanks Misha (my menu's in English too now ;))
By the way, according to the DOD website (for the F900LHD), if you have this menu then you have a fake camera
The other menu is apparently the genuine one :eek:
Offline meehalych
      Kolpino
This is a page of F500LHD manual, downloaded from DOD site http://www.dod-tec.com
 :P
Yeah I think the "how to check if it's a fake" section is itself a fake section  :disapp:
Offline meehalych
      Kolpino
that might concern F900 camcorder only as I found the same info in Russian DOD's site
hopefully you'll figure it out Steve,I'm still looking for a reasonable priced car cam.  awaiting your feedback.  :razz:
Well I've run my DOD for a few days now. Nothing special worth sharing yet. The quality is awesome - I can now review the video and see the letters & numbers on reg plates as well as motorway signs. It's crystal clear, then again at 1920x1080 (30fps)  and $137 it ought to be :)
Doesn't appear to be charging as I'm driving along, as I've noticed the battery level is reducing, but that's a minor issue which is probably down to a setting somewhere.
And yes, it's genuine, as confirmed by dod-tec.com
Offline asathorny
  • Wonky Donkey
  • Curmudgeon
OK Steve, when we see the evidence we'll believe ya  HAH AH aha ahh ahaha hahahaaa
Offline meehalych
      Kolpino
Check if this is set to "YES" - Menu - settings of video camera - USB IN (here must be 'yes'), otherwise, if the latter is set to YES, my advice would be - to insert another SD card with different capacity (16Gb for example, class 10)
Cheers misha but it seems to have sorted itself out (already had it set to USB IN=YES). It seems to [re]start charging when the indicator shows the battery is half full, then it starts building up again which is quite clever, tho quite daunting.
I'm using a 16gb CL10 card which is a good thing given the rate at which the video data is being written to it :eek:
All good stuff
so far,so good.  :razz:  hopefully its better than the last 3 or 4 car cams you've tried out.   :eek:
Just wondering how the new cam is going, Steve?  :undecided:
Yeah, if you're having any trouble uploading photos/videos let me know  :whistler: :rofl:
Offline meehalych
      Kolpino
I'm sure his one works prefect, so does mine  :P
By the way, I found the strap in a box  :)
Are either of you two guys planning to upload a video?
I see a model F520LHD, wonder what the difference is.
Offline meehalych
      Kolpino
eh, there are lot of my videos on this site
I found this one, is it from the subject camera?
https://www.i30ownersclub.com/forum/index.php?topic=10690.msg159794#msg159794
Although short, it appears to be of good quality.
Offline meehalych
      Kolpino
yes, this thread is mine alone with the video shots there
here is my thread too and my videos shot by DOD
https://www.i30ownersclub.com/forum/index.php?topic=11182.0
