I guess nothing is completely "idiot proof"...... Btw, did you read their mass air flow testing findings?http://www.knfilters.com/maf/massairfindings.htm
There was also evidence of motor oil contamination from blow-by; a condition where oil vapor from combustion is re-circulated into the vehicle’s intake tract.
This is worth a read too...http://www.knfilters.com/news/news.aspx?ID=422Could your landcruiser with the sticky oily coating have been caused by this?QuoteThere was also evidence of motor oil contamination from blow-by; a condition where oil vapor from combustion is re-circulated into the vehicle’s intake tract.
There have been problems with the oil from the K&N filters damaging the air flow sensor.
I'm not just pulling this out of my arse.
I've used K&N Filters for years never had problem,if you don't know how or when to clean em,don't use em.funny how you have knockers of oil coated filters,funny how no more than 50 years ago all you had was oil filled air cleaners,they never posed any problems,unless you didn't know what you were doing when servicing and overfilled them.
@surferdudeWhat method did you use to clean them
Obviously this is not a problem, due to the results that you have / are achieving, but in a paper element the focus is on keeping the dirt on one side of the filter only. They have compressible membranes top and bottom to provide an airtight seal. Now, after the first time the filter is washed in solvent, doesn't that allow the particles to get to the inside of the foam. Assuming the oil does its job I guess it holds these particles regardless of intake vacuum, but they are technically on the wrong side.
Yikes 5000 rpm, that would have m,ade a decent splash, was it navigator error,,,,, or driver
