Windscreen query.
VFouR · 9 · 2313
Offline VFouR
      Cornwall
  • Cornwall, UK. 1.6ltr CRDi Premium,Shine Red i30
Hi. I just wondered if the "Solar control windscreen" blocks radio signals?
For example to a Navigation Unit attached to same.
Thank you...
Welcome Bill03... :P
It's a bit ironic that the UK vehicles seem to come with this and the Aussie ones don't...I'm sure Shambles or Eye30 will have your answer....
Quote from: "dazzling_darryl"
I do not have sat nav.
I still rely on a map.  I like to "feel" my way around.
so unable to answer your query.
Offline teamgeorge
      Victoria
  • i30 CRDi sx Steel Grey 28/11/08
I tried to feel my way around once, got told i was doing it all wrong...  :lol:
I have an "athermic" windscreen which blocks UV and, as I found out, SatNav signals. But the coating isn't all over the glass. A good SatNav unit (like my Navman S90i), when positioned low down near the dash, works a treat.
Yeah I can't quite get my head round it, given the lack of sunshine we get up here  :?
Offline VFouR
      Cornwall
Thanks for the replies.
Apparently on athermic windscreens there is often a "clear" section at the top of the screen, behind the interior mirror. This area is left open for things like Toll Tags and Automatic door transmitters.
So if I have problems I will try sticking an aerial behind the mirror.
Offline sparki30
      Kent
Used my Garmin sat nav mounted low down drivers side works ok, but the bracket has not got quite enough movement to have the unit 'square' facing you, must be the angle of the windscreen as other cars I have used it in are fine.
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
Hi Bill
I have a Magellan Roadmate which has been in 3 different positions in the car and it works perfectly in all of them, despite the solar glass.
Brian
