New KIA Cee'd 2012
meehalych · 219 · 65664
Offline meehalych
  • Aircraft technician
    • ru Russian Federation
      Kolpino
I already have, but don't assume similarities in wiring, could be dangerous.
BTW, please take care on the road to Finland.  :exclaim:
could you post a schematic of wiring, that goes to the rear right lights?
thank you  :) I always do, especially in severe weather conditions
Sorry, why would I have that, I don't own a KIA.  :)
Offline meehalych
      Kolpino
I thought you have one of new i30  :)
2008 & 2010 I'm afraid.  :'(
Offline meehalych
      Kolpino
Today I have got closer to the plug I told you about and this time I had a better camera and multimeter with me
so I reckon this plug is a part of trunk's power socket, but I failed to find a fuse for it
here is a socket for my OBD scanner  :)
here is a photo of a driver's mat
I also decided to see if it was easy to change air and cabin filters and it turned out to be easier than it was in Hyundai i30
here one may see side restrainers, which proved to be removed and installed easy as compared with i30's ones
having removed restrainers and lowered a compartment we have an access to cabin filter's cover
there is the filter
and its cover with strange slits
In Finland I purchased a set of convenient plastic plates
@Misha
Suggest you connect an audio buzzer to the plug, then selectively remove& replace fuses 1 at a time until you find which one stops the buzzer.
Offline meehalych
      Kolpino
@Misha
yep, this thought had come to my mind, but it was late as I had placed lining back, so - next time, when I have a power socket
Does your Kia have a brake bulb testing feature (ie, tests the brake lights when you first turn the ignition key)?
Offline meehalych
      Kolpino
I don't know  :undecided:
Thanks for the photos Misha.. those "Plates" you bought in Finland :undecided: ... is that what you call tools ? (because they look like tools to prise things off etc...)
Offline meehalych
      Kolpino
yes, those things are tools for dismantling purposes, such as dash board removal etc so it enables to avoid unnecessary scratches, cuts and so on  (it cost me 5 Euro)
On my i30, when I turn the key to ignition, the little screen (which shows when a door is open) briefly shows my brake lights, before they disappear; that's there to test the bulbs.
Didn't your i30 have that?
I just thought that maybe your cee'd might have that feature in a higher model, but the wiring is there anyway.
Offline meehalych
      Kolpino
no, I didn't have it on my i30  :undecided:
I don't think any higher Cee'd model has this feature too, at least there is no info about it in a manual
That plug's wire length is too shot for brake lights
True, but it's just a connector, so it's meant to join up with something going further along.
It was just a thought.
Not sure, but I think it lights to test the instrument warning light only, not the rear brake lights  :exclaim:
On mine, it shows this, tho it does say "if fitted"
Offline meehalych
      Kolpino
have gone through a manual again, but found nothing similar to this
here is where a power socket is typically located in Cee'd trunk
@Shambles,
You are most certainly correct, sorry to mislead anyone  :-[
Offline meehalych
      Kolpino
a power socket that I ordered some weeks ago fitted well
so next problem that has to be sorted out is how to make a hole in a plastic fairing
by the way I have got two mishaps happened to my car, all of them caused by foreign objects flew from the other vehicles
here is a place where a stone hit my windscreen
and here is another ufo that came from the opposite road and hit my forward bumper leaving some scratches there
Not good Misha .. thing are always hitting cars in you country  :rolleyes: (usually other cars!)  :sweating:
Ouch! :(
Yes, I'd be happy with a small UFO.  :)
Offline meehalych
      Kolpino
in my childhood I dreamed of meeting ALF and hosting him in my home  :)
So far I have drilled a hole in a plastic and placed a power socket, time to plug a wiring and install a fairing  :happydance:
I'll have a power socket in a trunk at last
Alf was cool. Loved cats.  :D
Offline meehalych
      Kolpino
drilled a hole and installed a power socket a week ago, but took the photos this afternoon
Nice neat job Misha :goodjob2: :goodjob:
Nice little mod Micha  :goodjob:
Looks professionally done.
Offline meehalych
      Kolpino
a cat has found a place to have a nap in
