Auto Headlights - Too sensitive
pidim · 14 · 5324
Online pidim
I have new GD130 i30 Elite which also includes Auto Headlights. Does anyone find these to be TOO sensitive. Mine turn on even before sunset and I mean with reasonable sunlight in the afternoon.  In the morning before 8am, if I drive into a shady area, lights go on - plenty of sunshine around though.
And now I hand you over to......................................
Alan  :undecided:
Someone will respond. I don't know if the setting can be adjusted perhaps.
Offline Alasama
    • tw Taiwan
      Taoyuan County
Same as mine. And I don't think it's a problem to me.  I like it. :happydance:
Hi Pidim
You could always just use the manual settings  :winker:
My Hybrid has Auto headlights and I have the opposite problem .. I would sometimes like them to come on a bit earlier at night (and occasionally do it manually) Mine come on if I go under an overpass even on a sunny day .. :cool:
I have not noticed this problem with my car - the lights do indeed come on during the day if the car enters a deeply shaded area - such as driving through an avenue of overhanging trees or under a low wide bridge. However - I consider that this is safe behaviour.   It is better for the lights come on too soon rather than too late.
The light sensor is a small black dome at the centre/top of the dash - right against the windscreen. I assume your sensor is clean, not partially covered by anything or - and I trust you haven't - tinted the screen and thus fooled the sensor into thinking it is darker than it really is.
The sensitivity is not user adjustable - if you are convinced your car is far too sensitive - I suggest you ask your dealer for advice.
When the lights come do the DLR go out?
Yes - the DRL's do go out on my car when the auto headlights come on
I was expecting that reply as when lights are on, DRL should be off by law..
So a follow up question is:
Do the lights turn off automatically and the DRL's come on when the car returns to "normal" light conditions?
Just a thought:
The DRL's give a bright light at the front and do not distract drivers coming in the opposite direction.
In my opinion DRL's would be a better/safer option when in shade/reduced light areas as any sudden lights coming on may distract drivers, unless you need the headlights on to actually see where you are going.
YES !!!
YES !!!
Thank you
YES !!!
Are you sure about that, Alan?  :p :lol: :snigger:
