Tyre Advice
Twempie · 20 · 6963
Offline Twempie
Took my 1.6 CRDI CW for its third (37,500 mile) service the other day and was surprised to be told that I would shortly need a new set of fronts.  The tyres (Hankooks 205/55R16) were only replaced 12,500 miles earlier at the previous service.   The treads were down to 3mm, 2.5mm and 3mm from the outer to the inner tread. They have been run at 32psi although the dealer claimed that when they were checked at the service  none of them were inflated to the same pressure.
I've read other threads on the forum which suggest that the amount of torgue going through the front wheels might adversely affect tyre life on the diesels but still feel that the rate of wear is higher than might reasonably be expected.   I tend to drive conservatively and try to achieve decent fuel economy.  Don't know if driving style might be a factor in determining tyre wear?
Anyway, my main question is whether I should persevere with Hankooks or try a different manufacturer?  If so, what would members recommebd.  The other question I have is whether I am likely to have any problems having the TPMS re-set if I get the tyres replaced at a local tyre fitter or national chain if I choose them over the dealer?
Twempie
Twempie,
Take the time to go and read some of the topics in the "Tyres and Wheels" section. You may find a fair bit of information there.
In brief, there appears to be some issues, as you say, with tyre wear on the diesels.
TBH I remain unconvinced.
1/ Select a well known brand as a replacement.
2/ Run them at 36 psi and check them fortnightly. (if it was me with that problem, I'd run them at 38 psi)
3/ Regarding the TPMS, someone else on here can probably answer your question, or check what it says in the handbook. In my experience (in Oz) the cars we have fitted tyres to or done puncture repairs, the TPMS resets itself after a few klms of driving (provided the pressure is correct). Sometimes it's OK from the moment you fit the tyres, depending on the car.
Offline immx
      Essex
I can't comment on the i30 in particular, as I do not have one yet, however as a high mileage driver approx 50,000 a year, we always use CONTINENTAL PREMIUM CONTACT 2. and find them fantastic.
Pleanty of grip and the last very well.
Plenty of grip and they last very well.
Interesting, those Continentals have had several good wraps on here.. :goodjob2:
Offline Twempie
Thanks for the advice.  The tyres that wore out quickly were Hankook Ventus Prime 2's not the Optimo K215s that were originally fitted.
This time around I thought I would give the Hankook Kinergy K425s a go.  I understand that the K415s are being phased out.
The original K415s are still on the back with plenty life left.  I didn't fancy having different brands on the fronts and rears but will replace all four at the next change.
I'll add a few pounds of pressure as suggested and see how I get on.
Offline ElleB
  • Our Elle B
Hi Guys,
  Well you will remember that I took on being the guinea pig for testing the Mastercraft tyres on the i30. They are Mastercraft Touring LSR   195.65.15.
 They are Made in the USA, not mexico or elsewhere.
I have been running them at 36-38PSI and the car does more rural clicks than city.
We have just had them on for 11,000Kms and they still look like new.
I also fitted a camber kit, ~$90, bought online from White Industries in Sydney, so that I have max possible adjustment on the front wheels.
 The tyres are very quiet, have a 70,000 Km guarantee.
 I had them checked and rotated at 10,000Km and they were fine.
Both wet and dry driving has been good, so there has been no issues.
 I think it was about $110 each fitted and balanced.
 Google them to find a local dealer. www.mastercrafttires.com.au
 Once fitted, you will get a warranty card, that you get stamped each 10,000kms to keep the warranty valid.
 Hopes this helps......happy to answer any questions.
  Elle B
  • 2016 i30 CW auto
Wow.. Very positive so far then Tony and they were cheap too  :eek: :goodjob:
Hi Guys,
  Elle B
Thanks ElleB. I had forgotten who it was had fitted these. had to hope whoever it was posted an update.
Much appreciated.
Have bookmarked that address for later when I need tyres.  :goodjob2:
I had been considering Mastercraft tyres for my SLX but they are a bit too pricey for me....$172 each.  :undecided:
I'm now considering Continental's ContiComfortContact 5's at $147......
Anyone tried these tyres or have an opinion?
Pretty sure these are the ones Alan said to stay away from. Only because being a newer model they are supposed to be better but they aren't. He has written a bit about them.
Try to get Continental Premium Contact 2s
https://www.i30ownersclub.com/forum/index.php?topic=6874.msg82791#msg82791
The 5's are supposedly not as quiet as the 2's but having said that, my tyre guy raves about the 5's as well.
Thanks Trev....I did re-read Alan's comments and I think the only real issue as such was that they weren't as quiet. Otherwise they apparently offer improved tyre wear and better extreme wet grip...... :undecided:
I've only driven on the 2s and I certainly can't fault them.
I guess it comes down to price and if the 2's are still available.
That price seems exy for the Mastercraft. 16s or 17s?
Although I think the last time I looked they didn't have a 17 in our size.
The Mastercrafts were in the standard SLX size, Trev...205/55R16....
They did seem rather expensive, especially when you compare the price Tony paid for his 15" tyres......  :undecided:
They are out of my price range anyhow... :fum:
As for the Continental ContiPremium Contact 2's, I looked up the Jax Tyres website and they don't appear to have them in 205/55R16......  :undecided:
Btw, Jax want $169 for the ContiComfort Contact 5's so I'm certainly gonna support my local tyre bloke...  :eek:
The 5's are $149 fitted at my tyre shop.
Much the same as my local bloke then.....So it doesn't always pay to buy from the big blokes... :undecided:
Offline i30sean
      Hemel Hempstead UK
Twempie, I just had a pair of Hankooks 425 eco (flowers on side yes i know) from www.event-tyres.co.uk for £140 all in I got 20K out of my first set of Hankooks then tried Pirelli P7's very gripppy and stable but only lasted 14K.
I just had my 37,500ml service last week at Beachdale Hyundai in Derby was £173 but did have the brake fluid changed and re-bleed as brakes were a bit spongy. Plus they print on the bill C3 oil used  :goodjob2:
i30Sean
  • Midlands, UK N-Line T-GDi
I got 24K out of the K415's on the front. The backs will out last the car  :mrgreen:
I surprised myself and also bought K425s for the front as they were "good value". They are definitely better in the wet than the K415's were, and my ears say they are a bit quieter too.
