The intermittent mode does vary speed even on the rain sensing models.On yours when you enter Auto mode you should get an initial sweep as the system initialises. If you have the wiper on lowest speed you will get an intermittent wipe when it senses enough rain, but this can be sped up by twisting the dial to faster, however it is only useful if you find that the lowest speed and rain sensing is not working fast enough for you, in proper rain the intermittent will always be over-ridden by the auto system.Hope this helps!Brian
I have my intermittent on the i40 on the first "click" up on the rotary dial, which I also had on the i30.
The twisting knob has:->MIST->OFF->AUTO->LOW->HI
Seems like a dumb word for that... why not call it 'wash' or 'water'.
REALLY !!!!! I woz always under the impression that I had a faulty winder washer thingy... It's bloody marvellous this car
I'm just so happy that I have enough inertia which prevented me from getting a needle out and attempting to clear what I thought was a blockage..... See, it is sometimes better to leave things as they are
...I showed Claire how to use that function Hasn't rained since.
Quote from: surferdude on September 05, 2012, 10:09:47...I showed Claire how to use that function Hasn't rained since.So it's your fault
Soon, a Phd will be necessary for driving a car
Quote from: VaerO on September 01, 2012, 09:18:15Seems like a dumb word for that... why not call it 'wash' or 'water'.Not really, once upon a time when you washed the windscreen a single jet of water was pumped onto the screen and you spread it about with the windscreen wipers, initially creating bug soup which you couldn't see through, then you had to keep squirting until the screen was clear, however the dry bits which hadn't had water applied got scratched by the dirt and grime being dragged across the screen with no lubricant. Then they separated the single squirt into a dual jet and life got easier. Now when we pull the lever we get a fine spray of water which covers more of the screen, is more effective at lubricating the entire area and reduces scratches. This process is called misting, it is the same process for your screen as using a detailer spray on your bodywork, prior to clay or fresh contaminant removal
