R599 Car cam from Electromania. Not fancy but I stop allover and dont want something expensive they just gonna steel. This one does the job.
Pro's. Cheap, works, full audio. records up to 10 hours with sd card. Real time playback (I have used this twice) C below.
Con's. Not HD. Quality is a bit dodgy(But good enough for me). Battery life sux so has to be connected to car charger.
I also noticed my driving has inproved since I have had this as now there is a record of how I drive.
I have had one or 2 incidents here in SA where traffic police have pulled me over saying I did not stop at a stop sign, even when I did. All I do is say. Really? well lets look at the clip and as it has full audio, a fact I mention< suddenly i get oh ok you can go.
I have done over 700 000km in the last 10 years as a rep.
Specs
Electromann-Car DVR with 2.5 Inch LCD (Motion Detection, SD) DC35
Same specs as the R1300 one.
Tested both and no difference I could c.
Primary Use: Mini DVR with 2.5 Inch LCD Screen
* Image Sensor:1/4 CMOS VGA sensor
* Screen: 2.5 Inch TFT LCD Screen
* Mode: Video Cam / Picture Camera / Playback
* Resolution:
- Video: 1280x960 or 720x 480 (interpolated), 640x480 native
- Picture: 1280x960
* Recording Format:
- Video: AVI (motion JPEG)
- Files Size: About 800MB / 15 minutes
- Picture: JPG
* Frame Rate: 25 FPS
* Storage: SD/MMC card up to 32 GB
* Record Mode: Cycle
* Cycle Length: 2/5/15 Min per file
* Motion Detection Recording: Yes
* Time/Date Stamp: Yes- ON/OFF
* LUX Rating: 1
* View Angle: 70 degrees
* Built-in Mic: Yes
* Frequency: 50/60 Hz
* Connector:
- USB 2.0 (file transfer/Charging)
* Power Source: DC 5V
* Internal Battery: Yes
* Battery Run-time: up to 2 hours
* Dimension: 100(L) x 63(W) x 23(H) mm
* Certificate: CE, FC
