knock from front when braking
Hibs34 · 20 · 6749
Offline Hibs34
      Belfast
hi guys need help have a knock coming from front when breaking cant make out if the sides eg the breaks or from center of car sounds like a metal noise or knock its crdi 1.6 2010  going to get it bookef in but if I can find it it helps when I leave it in
have you recently had any work done on the car?  :idea:
Could be the drop links or other ball joints in the suspension, but then I would also expect it to happen when driving over speed bumps etc.
Offline Hibs34
      Belfast
yeh have had quit a bit all done by tge dealer but changed pads myself with non hyundai so im thinking might be that but ive used this brand on all my coupes with no probs
Offline Hibs34
      Belfast
all drops changed by garage and only 27 k on clock so dont think ball joints and like u sad it only happens when break peadle pushed
Is it just a single knock you can hear? If you start to brake and hear the knock and then release the brakes and reapply them, does the knock reoccur?
it could be the pads not fitting in the calliper properly,or you've not done up one of the callipers .  :idea:
Awfully low mileage to be replacing pads.
Were they worn out?
Did you keep the old ones?
If so, I'd be re-fitting them for a test.
Offline Hibs34
      Belfast
yeh one knock then kift off then back on then one knock again. there was bout 4mm left on them  im going to check all bokts tomorrow or buy genuine pads and leave it into the dealer im stumped what else it could be
Then I think it's the brakepads not fitting correct.
Do you still have old pads to compare sizewise to the new ones.. :question:
Could you have misfitted or forgotten one of those thin metalplates that keeps the pads in place.. :question:
Offline Hibs34
      Belfast
guys u are gems went and bought genuine pads and when took of the caliber the none hyundai ones fell out new one in all tight and no knock moral of the story just pay the extra money for hassle free driving   :happydance:
Glad you got it sorted.. :goodjob2:
I replaced the rear brakepad on mine at 172.000 km with OEM parts, no problems. I think you've just been unlucky.. :undecided:
Offline Hibs34
      Belfast
yeh but used them pads for years on every other car and no probs but sure big thanku for all the help
we're all here to help where we can.  :goodjob2: :goodjob: :mrgreen:
Offline komaterpillar
      Toowoomba
Hibs, it would be good if you provided feedback to the suppliers. Especially if you've used them successfully in the past. They'll most likely take it on board and make adjustments.
ouri30
StayFresh?  :undecided:
Isn't that "StayFree" :question:
Wife's input. :-[
Just Googled it - Free samples available :Shocked:
Wife's input. :-[
Thanks.
Just shows what I know.  :lol:
Offline Hibs34
      Belfast
they were mintex quite good pads even for dust
