Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
May 23, 2024, 05:35:10
GOT PROBLEMS OR ISSUES?
PETROL
Fumes in Car
Fumes in Car
Yorkrose
6 ·
2770
« previous
next »
Print
Pages:
1
Go Down
Yorkrose
1st Gear
7
Australia
Cronulla New South Wales
Fumes in Car
January 22, 2013, 08:49:27
I have had my 2011 i30 SX for two months now. On numerous ocassions whilst driving I have noticed that the fumes from the catalyctic converter are coming in to the cabin. It's been so bad that even my grandchildren have complained about it. The air vents have been switched to interior circulation. It makes no difference if the air conditioning is on or off. Could it be that it needs some filter cleaning or some other adjustment? Has anyone had a similar occurence?
i30 FD Auto Sedan 2011
Dazzler
Admin
Laughter is the best medicine...
67,423
Australia
Best Car Forum on the Net
Re: Fumes in Car
Reply #1: January 22, 2013, 08:52:13
Can't say I have heard of that before .. I would be getting it checked thoroughly by the dealer (sounds like a health and safety issue)
2021 MG PHEV ( had 4 x i30 plus a Getz an Elantra and a Tucson)
Phil №❶
Top Gear
Loco, most of the time!
21,976
Australia
Re: Fumes in Car
Reply #2: January 22, 2013, 09:13:38
This needs looking at.
Why do you specifically mention the catalytic converter, do you have any issues with this device. The catalytic converter is just part of the exhaust system and if operating correctly, can only pass gasses to the rear muffler and then out the tail pipe. This is the ONLY allowable exit point for exhaust gases. For fumes to be present in the car gasses would have to enter from the rear hatch seal, door seals or an open window. All these need checking IMO.
I have never smelt any exhaust at all whilst in the car at any time.
2008 SX CRDi Auto White (Lila)[hr]2010 SLX CRDi Auto Red (Ruby)
Yorkrose
1st Gear
7
Australia
Re: Fumes in Car
Reply #3: January 22, 2013, 10:01:02
I mentioned the catalytic converter as the smell that comes into the car is the same smell that you sometimes get from vehicle exhausts. It is like a rotten egg gas. Not being mechanically minded I can only point it to that source. It appears to come from under the dash of the vehicle. It is not noticeable if the windows are down. I doubt that it is coming from door or window seals.
Phil №❶
Top Gear
21,976
Australia
Re: Fumes in Car
Reply #4: January 22, 2013, 10:09:08
The rotten egg smell, is hydrogen sulphide, a component of petrol combustion I'm afraid. I believe it comes from fuel that has a high sulphur content depending on its geological origin. The catalytic converter is supposed to be sealed as I previously mentioned, however, if you feel it is coming from the dash area then the dealer should do a detailed inspection of the whole exhaust system as there may be a gasket fault in that area. Usually, there will be tell tale signs of gas leakage.
Yorkrose
1st Gear
7
Australia
Re: Fumes in Car
Reply #5: January 22, 2013, 10:13:08
So it's possible that there may be a worn seal or gasket around the exhaust system. Back to the dealer, I think. Many thanks to all for your help.
Print
Pages:
1
Go Up
PETROL
Fumes in Car
Search
Username
Password
Always stay logged in
Forgot your password?
