What's the difference?
bryand · 7 · 3114
Offline bryand
      Loughborough
On the UK market, the Style trim level gets a 1.6 diesel rated at 110 PS (81Kw) whereas the higher-specced models get the 128 PS (94 Kw) engine.
Is the difference between these two simply the engine mapping?  In which case it should be relatively simple to bring the 110 PS engine up to or beyond 128 PS.
  • 2011 FD i30 1.6 Diesel
Member accim had something similar done to his first CW (FD series) :cool:
Just check HY UK site and for the 5 door Style there are 3 available engine size's:
http://www.hyundai.co.uk/new-cars/i30
1.4 100PS Petrol Manual
1.6 CRDi 128PS Diesel Blue Drive Manual
1.6 CRDi 128PS Diesel Automatic
No mention of the 110 ps.
The Active has the 1.6 CRDi 110PS Diesel Blue Drive Manual engine.
Offline bryand
      Loughborough
Sorry, I meant Active not Style.  But the question remains: is it just the mapping?
You would have to ask Hyundai engineers, we don't build them.
Offline bryand
      Loughborough
Hmm.  So much for the DIESELS > MODIFICATIONS forum then.
All forum sections are initially created empty. The content that appears in these sections builds by the valued input of the forum members. If you can't find the answer to your question it's probably because no one has, or feels the need, to perform your modification. You could assist the other members by doing a little research and add to the knowledge base, rather than voice your frustration.
At a guess, I would say it is in the mapping as there are no gross mechanical variations between the engines.
Try using the search function & look for mapping, I know there are some people who advocate remapping rather than adding a simple "performance chip". Hope that helps a little.
