Head unit lockup
Offline Aussie Keith
      Fitzgibbon, QLD
    • Keith and Joan's Gallery
Last night and for no apparent reason the head unit locked up refusing to respond to any of the buttons. It was playing media via BT at the time which I frequently do. It reset after turning the car off for a while however this is not always going to be a convenient solution.
Has anyone seen this before and is there a proper solution?
Keith
Offline plasticphyte
  • Bazinga!
  • Bazinga!
I haven't had a lock up occur on my GD i30, but I have had the program jupiter.exe crash, taking the entire GPS subsystem down with it. The only way I was able to resolve it was by turning the car off for a while, then back on again. It seems like a painful way to reboot the wad unit computer.
I had tried turning the head unit off then back on again, but that hadn't worked.
The head units run Windows CE embedded, so I'd suspect they will be prone to crashes/freezing at the most inopportune moment.
  • i30 Premium 2012 1.6l Diesel
Offline pidim
Iv'e had a similar problem also. I was BT streaming with an iPhone and it got stuck and froze.  The only way I could unfreeze the system was to turn off my iPhone 4S. I think the iPhone is the culprit personally because ever since iOS's latest update I've never seen it happen again.  Hope this helps
I've had the same thing happen once when I was using the Bluetooth phone connection.
It just froze and I had to switch engine off to disconnect the phone, restart the engine, allow the phone to reconnect, then it was all OK.
It hasn't happened since.
ouri30
Correct me if I'm wrong, but doesn't the headunit have a reset button.  You need a small object like a paper clip to push it in.  I think it's on the left at the top.  Haven't had to use it yet.
Not sure, I'd have to check that.  :undecided:
ouri30
Just checked and the reset is just above CD eject button.
