RPM at tick over
eye30 · 16 · 6236
Never really noticed before but today, temp outside a barmy 15c, the engine ticked over as follows:
First start from laying overnight, say 14 hours, 1250 rpm.
Once at operating  temp, 6 mile trip, 700 rpm.
In both instances the engine was quiet and very smooth. In fact I thought it had been turned off but no nice smooth 700 rpm.
I'm sure before the service on Monday the revs at warm were around 800.
Anyone care to enlighten me with technical details for rpm  at cold and operating temp.
Who knows, with computer control over idling speed, air temp / pressure & engine temp are all used to determine a satisfactory idle, could be different for each owner.
Offline Just Rick
  • Big Dogs Rule
      Beverley Western Australia
  • miracles can happen
never really noticed,get up in the dark open shed door throw in work bag and mug of coffee,work bag in the boot cup of coffee in cup holder,start car,drive out of shed,jump out(after stopping)shut shed door,then jump back in and drive 124k's to work,park sit there gathering my crap together while the car idles down,still haven't looked at the tacho,turn the car off and then go clock on.
end of the day is a reverse of the morning
Do you drive that distance to work every day Rick or do you stay down in Perth sometimes?
Based on his km's, he commutes.  :exclaim: :rolleyes:
Offline Just Rick
  • Big Dogs Rule
dave do it every day,I used to stay in Perth,but there are things that need attending to here and it was getting to hard to be away for four days at a time,basically go past your way every morning early
What's your route (with your truck)?
Offline FatBoy
      Cygnet, Tasmania
Nice commute, Rick.  Mine is 75km each way, but I wouldn't have it any other way.  I love where I live and I like my job.  My commute is only an hour as well.
As for the idle speeds, I haven't really noticed.  I do notice that it is higher when the engine is cold, though.
I only looked at the tacho as I thought the engine had stalled/off as there was no/hardly any engine noise.
Offline Just Rick
  • Big Dogs Rule
Depends on what I do durin the day dave,today I was up at Ellenbrook,then back to the yard to get a milkrun from kewdale to canning vale,forrestdale and then baldivis,so depends wht is on the run for the day,sometimes I just run local around kewy and forrestfield.
Offline Just Rick
  • Big Dogs Rule
yes mines 124k each way,same love were we live,mind you would be nice if they had a couple of country runs,so I could possibly bring the truck home instead of using my cars all the time.
eye30 normally cold mine runs around 1000-1100 but once warm ony runs 700-800
Offline Keith
      Telford, Shropshire, England.
Fast idle when cold is perfectly normal.
I'm ok with the 1250 when cold.
I was expecting little bit higher when warm, say 750-800.
Anyway as the engine is governed by the black box syndrome I take it this will alter the rpm's depending on such factors as temp, load and the nut holding the steering wheel.......
Offline ryane
      Sydney: Blue mountains
15 degrees is balmy??? beautiful morning up my way!!
With winter kicking in, last week we had constant 2-3 degree mornings when i was getting up at 3am for work, similar to rick its normally a routine of bag in car, coffe in hand, but i always waited for the FD to get to atleast 32 degrees before driving up.
On start up it sat around the 1100-1200 mark and slowly droped down to about 800. Then after a good drive to work it would idle around 700.
After being ran into from behind and then hit from the side, still idled at 700 :rofl: :rofl: :rofl: :rofl:
I like your sense of humour after what you went through
Offline murrakami
My 1.8 petrol GD is similar.  Around 1200 on start up and then idles at 700.
  • hyundai i30 GD Active
