Inside door handle not working
feldom · 3 · 1985
Offline feldom
      Ilkley
  • Ilkley, West Yorkshire, UK
Hi,
I pulled the drivers door handle to get out of the car and nothing happened. Had to get out the passenger side. Did a quick check. Drivers door outside handle works OK, as does every handle in the car. Central locking no problem. It is as if the electrical connection to the inside handle has "dropped off". It is under warranty so I will take it to the dealer. Just wondered if there is a quick fix to save the hassle?
Cheers Mike
Same happened on my old crdi.
Told it was a linkage clip which had come off.
Hi,
Cheers Mike
Probably easy enough to re-attach it yourself but I'm never keen to take the door linings off..
