Yes but, would you rather be trodden on by the toe of a stiletto shoe, or the heel. Same downward force but completely different effect. Even though I know you are correct, it must have something to do with co-efficient of grip.
But if it's spread over a larger area then the pressure must be substantially less at any particular point, therefore, the chance of slipping must be easier to achieve, yes / no ?
Quote from: Phil №❶ on August 08, 2013, 09:25:19But if it's spread over a larger area then the pressure must be substantially less at any particular point, therefore, the chance of slipping must be easier to achieve, yes / no ?PhilI'm just a simple bloke your now just flumexing me with lodgic I know lodgically what you are saying sounds correct but in reality it is not what happens Suferdude Hhheeeeeeeeellllllllllppppppppp Pleaseeeee
