For those without keyless entry and start..
With my car I have a remote fob (with a key hidden inside it in case of a fob or battery failure)
When I get out of the car I just touch the door handle and it locks (with one beep) I have to lock it with the remote lock button if Trish leaves her handbag in the car with the spare key in it.
When we return to the car if locked by remote then has to be unlocked by remote. If we have locked it by touching the door handle then I just grab the door handle (with key in my pocket) and driver's door only unlocks.
Trish has spare key in her handbag. If she grabs her door handle (passenger side) all the doors unlock.
WAlk to the back of the car with Key in Pocket or key in Trish's handbag (within roughly a metre of the lock) and can open boot by just reaching under the latch (or touching boot button on Remote Fob)
To start the car just touch button on dash with key on your person (or in your pocket)
Once you get used to it, just so easy and convenient!
Exactly the same as my i40.
There is a key inside the fob which can be used in the event of battery failure, the key is used to prise a cover from the passenger door handle which reveals a standard barrel. The car can still be started by holding the fob (I assume it has a power reserve with limited range) on the start button.
I agree about the ease and convenience, it did puzzle me though when I first picked the car up and got out at the end of the first journey, couldn't get it to lock by using the button on the door handle, it just kept beeping at me, then I realised that the spare key was in the handover pack from the dealer and in the secure tray under the boot floor, that was when I found out just how clever it actually is! Like the Toyota system though using the fob buttons does over-ride the keyless system.
