1.6 crdi 2009 catalytic converter removal
borb12 · 11 · 5578
Offline borb12
      Northamptonshire
Hi all i was thinking is it worth while removing the catalytic converter but leave the dpf in place has any one done this? or is it best left alone, i was thinking if removed would it help turbo up spool up time and would it throw a check engine light on
  • i30 FD 1.6 crdi
How are you going to pass the MOT if you do that  :question:
It's Illegal to remove catalytic converters due to anti pollution laws but you do have a choice of performance versions with much higher flow rates, I'm not sure whether the flow rate increase would require ECU tuning modifications to compensate though.
Offline TheReaper
  • Mad Medic
      Newcastle, NSW
  • Live laugh and love
:wttc: borb12
Dont remove it....
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
The 'ECU' on the F-35 Lightning II Joint Strike Fighter certainly needed retuning when jet nozzle dimensions were changed, to avoid jet blade overspin. The i30 comes close in performance so I'd say yes. :victory: :snigger:
Offline borb12
      Northamptonshire
Thanks all for comments it would pass mot as would get the original cat and remove the insides and refit, so will still pass mot as wont know it is removed, i do know is Illegal so a sports cat might be an option has anyone fitted one.
  • i30 FD 1.6 crdi
Once the car goes in for servicing issues would appear straight away once the exhaust flow sensor starts showing excess contaminates, then you'll be up for a couple of hundred $ to fit and replace.
I've upgraded the catalytic converter, extractors and exhaust system on a Mitsubishi Mirage 1.5Ltr before as they come standard with a little pea shooter of an exhaust system which had great results but as you are talking about Turbo Diesels I couldn't really comment, I would think though that to get any real flow benefits you'd need to upgrade the standard headers to performance extractors with free flow mufflers as well and as like mentioned previously you would also need to have to ECU modified.
Is it worth it :undecided:
Surely once they stick the probe in the exhaust it will show a high reading.
 :whsaid:
If you really want better performance, get the ecu remapped. That will leave you with around 140 HP / 310 Nm
