Low Washer Fluid warning light will not go out
flobalob · 22 · 22020
Offline flobalob
      Southampton
Washer fluid warning light came on and so I filled the reservoir (it was low) but the warning display will not switch off. Any ideas or fix? Thanks.
  • i30 active 1.4 petrol
Only a shot in the dark but some members have disconnected the battery to reset other functions.
ps leave for about 30 minutes
« Last Edit: October 01, 2014, 13:55:02 by AquaBlue »
Should extinguish after you've driven a short distance.
Offline Just Rick
  • Big Dogs Rule
      Beverley Western Australia
  • miracles can happen
You lot over there are lucky,I got no washer warning light,ran mine out about a week ago,Bugger  :lol:
Offline flobalob
      Southampton
Already driven several miles, no luck.
Does water now come out the nozzles or is it blocked?
If no water may be the unit is faulty
Offline flobalob
      Southampton
Everything works fine apart from the low washer fluid warning not going off, no blockages anywhere.
Another idea...
If you have tried the battery disconection, take the fuse out and put back in and see if this resets it.
or
If not tried battery disconnection take fuse out away and put back in.
or
Trace lead to washer unit and remove lead.
Make sure connectors are clean and reconnect.
and finally....
if still under warranrt take it back to dealer to sort out.....
I have the same issue - dealer says it "needs a new sensor, which is on order" - to be replaced under warranty so I didn't look the part up, I can if you need the part number.
Amazing how easy life is with an FD. :whistler: :lol:
Offline flobalob
      Southampton
Just to say after some more outings it's finally gone off  :D
I thought it might.
Offline flobalob
      Southampton
It's just that all times previously it went out as soon as the reservoir was filled and the ignition turned on, I'll know better next time.
May still be a faulty sensor like Lorians..
Offline simowizard
      Cameron Park
  • I love my SLX i30
Hi.
Here's just a stab in the dark. Although I haven't experienced this issue with my i30, I did have a V8 Calais that had sensors everywhere measuring everything. Once my windscreen washer fluid sensor did what you said by not going out after refilling. What I did was to reach under the bottom of the water bottle and gently "tap" it a few times to shake loose the float which had became stuck on the bottom. Once it free'd up and floated, the sensor registered "full" and the light went out.
Give the gentle "tap" a try and if that doesn't work, Hyundai will always be above excellent in repairing warranty issues.
I love my :i30:
  • 2011 (FD11MY) 2011 SLX CRDi six speed manual hatch
^--- that's a fair call. It's what I would hope to have happened when I mentioned to "drive around for a while".
Offline flobalob
      Southampton
Thanks for all the replies and advice, will try the tapping next time if it doesn't go out.
looked in my bottle and can not see any float.
isn't it just a sensor built into the connector thingy~?
No floats just a sensor near the bottom.
So you reckon it's a tappet problem then... :snigger:
Mine was a little temperamental before it failed.
There is little point in tapping the reservoir, it doesn't have a separate float.
When it does fail this is the part, and its fitted from below the reservoir:
Offline Ranyanem89
    • za South Africa
      Secunda
I am also getting the same light don't know whats wrong.....
  • I30
