How do I remove the badges on the boot?
Guest · 7 · 4042
I'm sure I read it somewhere here but can't find it.  I was thinking about removing the CRDi badge.  It always looked crooked to me.  Just had a close look, it must be put on by hand because it sure looks crooked to me!
Anyone know how to get it off without damaging anything?
Thumper mentioned something here
Hmm, I thought I had done a write up on removing the badges?
Might do one, since I have all the photos here.
Parts needed, a normal hairdryer, some metho and a little bit of paint polish (If there are any scratches left over) Shouldn't be, but just in case.
Another method is using fishing line to 'cut' through the glue between the badge and the paint.
Offline KKOM
    • gr Greece
      Heraklion
You can use an ordinary hair dryer pistol and for any remaining glue clean with WD-40 spray.Believe you will get surprised how easy cleans glue and many other things (http://www.wd40.com/uses-tips/)
Offline freakzoide
I removed mine and didn't even needed a airdryer. (it was a hot day).
Just used some sowing line and cleaned it wish some detailers polish.
Now they've found another 1960 uses they should re-name it WD 2000+ (handy link thanks...)
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
That is because WD-40 is a mix of PTFE beads in an alcohol based solvent.
I have been touting alcohol on here for a while now as a cleaner for glues which will not affect paint, glass or plastics :rolleyes: :razz:
I have been touting alcohol on here for a while now ...
Yeah - thanks for the hangover :lol:
