Suggest if blade is universal cut it to length before fitting.
My 2009 model doesn't need all that. The blade just pulls out. You do have to slightly distort the blade to clear the end bits.It's done without removing the wiper arm. Just lift it off the glass.Replacement of the new insert requires the same distortion.
Quote from: Surferdude on October 25, 2014, 20:37:26My 2009 model doesn't need all that. The blade just pulls out. You do have to slightly distort the blade to clear the end bits.It's done without removing the wiper arm. Just lift it off the glass.Replacement of the new insert requires the same distortion.Yes been there done that,each replacement blade I have used,have never worked as well as the replacement arm
