Question about bluetooth and voice control
Offline cobra8888
Hi, just bought a 2012 i30 crdi style today. However, the bluetooth and voice control does not seems to work when the stereo switched off, it works perfectly when the stereo is on. Is there any fault with the system or is the the way it works? Apart from this issue, the car drive wonderfully.
Thanks a lot for any help.
  • 2012 1.6 crdi Style
Yes the stereo system needs to be on for Bluetooth to work, it cant pair with the device otherwise.
I don't know about voice control as I don't have that feature on my 2013 i30 :confused:
My 2014 Style Nav also disconnects the BT/phone when the radio system is off. It follows that voice control is also disengaged with no power to the mike.
Online eye30
I have it on my car.
Tried to use it and gave up as it consistently failed to recognise my command.
ps
there is a detailed voice command vocabulary in the Handbook which you need to learn off by heart to ensure the correct words are said
pps
need to have radio on to activate bluetooth
Offline cobra8888
Thanks a lot for the replies. Will I still be able to receive call using Bluetooth when the system is off? Can I use the voice command when the stereo off?
It seems strange I will have to switch on the stereo ever time I drive just to use the hand free function.
Quote from: cobra8888
Quote from: CraigB
Online eye30
No to both.
The radio has to be on.
Turn radio on and turn sound right down.
If you don't want the screen to be light turn that off by pressing the button with a moon on it.
Offline cobra8888
Thanks. One more question, is there any way to dim the brightness of the stereo display? I tried to use the dimmer switch on the right of the steering wheel but it seems like only dimming the brightness of the clock binnacle but nit the stereo display.
Online eye30
No and Yes
No you can not dim but
Yes you can turn light off.
There is a button to press.
Check handbook for details for your model
Offline lyon
      South Melbourne
I don't think I have it as well on my 2014 i30.. must be Australia's model  (plus, no daytime running light as well for us  :'()
  • i30 Premium 2014, Creamy White, 1.8L Petrol, Auto
I've got the DRL's, mines a 3dr :D
Craig's 3 door and my wife's Tourer are imported from Europe and get Drls. Your hatch is from Korea and at this stage no Drls :pout:
