Will 19'' mags fit on?
Offline SteveI30
    Just wanting to know if a set of 19''mags will on?? Ne1 done it out there?
Thanx Steve??
Offline blawler
They might. The arches look big enough. But the ride would probally be quite rough.
hemmis rims are 18" [i think]
It can be done... I searched this site under wheels
and found this thread..
https://i30ownersclub.com/forum/index.php/topic,471.0.html
There are 8 or 9 pages in the search so there could be more...
Offline Goldfish_8
      Toytown
It should be possible to fit 19" on, you would probably need to use a 225/35 r19 tyre to make it work, and there seem to be a good selection of tyres in that size. Only thing is finding a wheel with the correct offset of 45, or near as damn it to avoid rubbing, and finally, the speedo will be marginally under reading, so you will be going faster than the speedo indicates on that tyre size.
I have the 18" MS Design alloys which come with 225/40 r18 tyres plus I have the Hyundai lowering springs, and there is no rubbing, and ride comfort is acceptable, even with XL (extra load) tyres fitted.
Mark
Offline bloodnut
They will fit no worries, as a posted above, the offset is the important thing, i currently have them on my wifes sx, with standard suspenion i have not scrubbed inner guard yet, bit bumpier, but turns better.
Regards Bloodnut :D
