Blown 6 headland bulbs and 2 side lights in 6 months
Offline Mattlostatsea
      Kent
Hi. My company car I30 has had all the recal electrical work done for the headlamp looms but the think keeps blowing bulbs, the recent bulb only lasted 3 days. It's out of warranty now as well. any ideas? Cheers
  • 59 Plate I30 Diesel
If as you say, all electrical work has been properly carried out, then that doesn't leave many options. In your country, I believe there were Hy TSB's released to correct lighting problems. You should check with your service dept to ensure all were carried out.
I have a theory, which may help.
The bulbs are possibly absorbing voltage spikes created by either the alternator or the starter motor back EMF.
- If your car is fitted with the auto light function, don't use it. Switch them on only after engine start.
- Before cranking the engine, turn your fan on to high, this will create an electrical load to absorb any voltage spikes that may be present when cranking.
As your car was attended to under warranty, the lighting issue should still be covered by HY due to previous history. They MAY subsidise the cost of the replacement globes out of goodwill.
Let us know any further developments.
 :welcum:  :whsaid:
The fix apparently relates to the earthing of the lights. It might be worth checking any obvious earth leads they have added to ensure they are grounded.
It is a fairly common fault for the CRDi to blow a globe or two a year. Not sure why some blow a lot more and some don't blow any!
Do you drive with headlights on during the day?
You have a five year old company car?
Look right behind the battery. There are three earth leads bolted to the chassis, are they corroded? If so clean (abrasively) and cover in lithium grease.
For the record the Tsb for the wiring 12 months ago seems to have helped the blowing. Can you see the extra plastic wiring additions with blue ends tucked in behind the lamp houses?
 :Agoodpost: :goodjob2:
