Apparently no major damage. Replacing hose, clamp, flush and pressure test. Pick up tomorrow. Temp was on the stop in the red.
Quote from: FatBoy on February 18, 2015, 07:07:28Apparently no major damage. Replacing hose, clamp, flush and pressure test. Pick up tomorrow. Temp was on the stop in the red.If it tests o/k over the next few weeks you better buy a Tatts ticket!
Obviously I know the southern outlet well.
I got Homer back today. All work carried out under warranty too!! They even gave the car a quick detail. Well done to Motors at Hobart.
Good on Motors at Hobart.Is that the correct name?
Quote from: Doggie 1 on February 19, 2015, 10:24:02 Good on Motors at Hobart.Is that the correct name? That's them. Motors Hobart Holden & HSV | New & Used CarsDazz, check out the demo Calais V that is for sale for $49,990. You too could join the 6 litre brigade!!
If I'd wanted the thirsty V8 I would have bought one! They had a prussian steel v8 on the lot up here a while back cheap but I like my white V6 thanks..
Quote from: Dazzler on February 19, 2015, 11:30:32If I'd wanted the thirsty V8 I would have bought one! They had a prussian steel v8 on the lot up here a while back cheap but I like my white V6 thanks.. Is that the same as the Rent-a-Flog hire Car Company use? Toyota hybrids are much more refined, I believe.
Hope this doesn't get removed....
Quote from: FatBoy on February 21, 2015, 10:59:32Hope this doesn't get removed.... Your particular knob is G rated, Jamie.
