new rims
jesam · 18 · 4105
Offline jesam
    • cy Cyprus
      kyrenia
« Last Edit: February 19, 2015, 17:56:51 by jesam »
  • hyundai i30 2008 crdi
I do like those :goodjob2:
You'll be needing a new avatar :winker:
 :MeToo:
Offline cruiserfied
  • Crooked-H Hero
Looks good. They remind me of a factory rim but cannot remember what car.
They look like a combo of the higher end i45 wheel and ix35 wheel and also remind me of the Dualis Ti wheels (which i like)
Offline Johnno
      Bolton, Lancashire
Looks good :goodjob:
Offline cruiserfied
  • Crooked-H Hero
Found them. Well the right vehicle came in to the workshop at the right time :D
DM Santa Fe Highlander.
:goodjob:
Looking good, jesam..  :goodjob2:
Offline jesam
    • cy Cyprus
      kyrenia
Just ordered new lowering springs  30mm on the back 35mm on the front .then when fitted see how it looks then time to do adjustable  rear trailing arm kit from shark racing  :winker:
Offline CraigB
      Perth, WA
Looks good :goodjob2: I've to do the lowered springs soon myself too but at a 20mm drop I shouldn't have to worry about the rear arms :Good_luck: but if I do it's an extra $200.
Offline jesam
    • cy Cyprus
      kyrenia
I think 20mm all round should  be fine  so you shouldn't have to buy adjustable arms but they do give you a lot more flexible in personalised set up  :victory:
Offline CraigB
      Perth, WA
Yeah I'm hoping there is enough standard adjustment built in, I don't need to personalise to much as I only want to close up a little of the gap and I'm not racing so don't need serious camber adjustment, making sure the tyres don't wear on the insides is all I'm concerned with :)
Offline jesam
    • cy Cyprus
      kyrenia
Yeh good point  about the tyres but  20mm should be absolutely fine on standard arms  :happydance:
Offline jesam
    • cy Cyprus
      kyrenia
M8 sweet wheels I'd definitely get new arms 20mm drop your car will have a really nice stance  :goodjob:
Offline CraigB
      Perth, WA
Thanks :) just have to wait and see how it turns out once it's lowered, being a euro model ( independent rear ) there is more play to work with so the arms hopefully aren't needed.
Offline Raid
      London
  • Nobody is perfect.
http://www.dropbox.com/s/g9j74g7wlr43de7/20150219_171338.jpg?dl=0
http://www.dropbox.com/s/ac5bshnrff0ko3a/20150219_171349.jpg?dl=0
Got some new rims today and yes car needs to be lowered  :happydance:
Hello mate nice rims you got there and would you mind to tell me how much you bought them for and where plz
« Last Edit: July 29, 2015, 11:51:53 by Raid »
  • I30 active 1.4 petrol 2013
