Performance header o2 sensors
esnow1 · 11 · 4713
Offline esnow1
    • us United States
      Greenwood, South Carolina
I have an Elantra Touring that I have been modifying, I found a performance 4-2-1 header that will bolt up and that utilizes both o2 sensors, the one in the top of the stock manifold also the one in the down pipe, but it will no longer have a cat on it, so when I put the new header on, and plug in the factory o2 sensors, will I get a check engine light because there is no longer a cat on the exhaust anymore, or will it be fine since the new header will still let me use the factory o2 sensors.
  • Elantra Touring SE
The CAT is after the o2 sensor so it wont affect on-board readings but removing the CAT will render your vehicle illegal and if you ever have to have your car serviced this will become an issue :eek:
Another thing to think of is the cars computer could possibly need remapping after installing extractors as well as the air flow past the sensors will change dramatically :undecided:
« Last Edit: February 24, 2015, 15:19:11 by CraigB »
Offline Johnno
      Bolton, Lancashire
Depending on how strict your laws are for passing the emission test  you could fit a 100cpi hi flow or 200cpi sports cat, tests here in the Uk have shown the hp increase with a system which as been de-cat and one fitted with a sports cat is negligable.
Also is there not a lambda sensor on the cat? which if the cat is removed will have to be in-corporated into the new replacement pipe
I had a 100cpi race cat on my other car and it just manages and I mean just, always took a few attempts to pass the emission test, here in the UK
« Last Edit: February 24, 2015, 15:40:56 by Johnno »
Offline Wingerdave
  • Brummie born and bred
    • nl Netherlands
      Raamsdonksveer
If your not interested in emissions why not buy a seventies muscle car? Nice little 'Cuda ?     :victory:
Because that's a hell of a lot more expensive than a set of extractors.
Offline Wingerdave
    • nl Netherlands
      Raamsdonksveer
But it would be sooooo cooooool  :happydance:
Offline snakoil
from my experience, the second you remove CAT or change headers on a 2000 and up car you get a CEL
Back in my 2006 Lancer ralliart I had a custom downpipe and high flow cat, i tried the plug extender solution and worked 1 day out of 2
I saw there is now an electronic device that simulates the signal, haven't tried that one yet
Offline Johnno
      Bolton, Lancashire
you must have something not setup correctly.
i had pre-cat and main cat removed and just fitted a new downpipe and 100 cell race cat and I never had any problems, the new pipes had fittings tapped out in the pipe to re fit the sensors and it never threw up any codes
Offline i30mad
      Welling, Kent
just gut the cat, take its internals out and refit cat least you can still plug downstream sensor back in, any car in uk without a cat pre 2000 is a instant mot failure..
  • I30 2.0crdi premium,remapped 203BHP
Once your take the core out of the catalytic converter you'll fail the mot anyway as the exhaust emissions test will fail :disapp:
And you'll get DTC's for O2 sensors.
