Smelly A/C
msoon · 20 · 6141
Offline msoon
Hi guys.
I've got an i30 SR that's about 9 months old and I'm getting this odour from the ac vents during ac start up.
The smell is musky like an armpit (but I swear it ain't mine) and it only started appearing a few weeks ago. The smell disappears after about a minute each time I run the AC unit -  then it disappears.
I've tried the AC spray where you spray the vents under the wipers from outside the car. Helped a little but the smell is still there.
Just wondering if any of you have the same issue?
Mark.
  • 2014 i30 SR 2.0 L 5 Door Hatchback
Offline cruiserfied
  • Crooked-H Hero
Any signs of mice/rats under bonnet.
Offline msoon
No rats or critters :)
Offline msoon
The linked thread wasn't very helpful unfortunately. Is there a way to access the condensation tray without taking the car back to the workshop?
Will it also do it if you have it set to recirculation... :question:
That way you might be able to find out if it's from inside or outside.
Offline msoon
It's definitely not from the outside. It happens regardless of where I am
Your car is very young to have this problem.
  • Have you checked that the Condenser drain pipe is not blocked and drips condensate on the ground when the AC is running in humid weather.
  • Has your car ever been flooded with dirty water due to rain or creek overflow.
It sounds as though there is some build up of material that is degenerating and causing this smell.
If you use the AC, you should turn the AC off for a few minutes before stopping to allow the air to dry the condenser fins, this may help.
Check under your carpets for any evidence of moisture, this can cause a smell, too. Sometimes the leak can be from a faulty door seal which allows rain to enter low down.
Offline msoon
How do I check the condenser drain pipe? It's definitely not the carpet.  I'll do the turning off A/C thing in the future, I'm sure something is blocking the drain pipe which causes the musty smell. Just need to know if there is a way to access the condensation tray?
The drain pipe outlet exits the interior through the firewall of the engine bay just right of centre, from memory. There should be a black open ended tube pointing down. I would poke flexible plastic up there to see if mud etc. is blocking. Don't use a screwdriver as you may bend a fin.
If the tray needs dismantling, it's probably best left to a professional.
Offline Gruntus
      Qld
the pollen filter may be another thing to check
  • 2011 slx crdi
Offline msoon
Can I access the pollen filter without going to the service centre?
Offline Gruntus
      Qld
It's usually located behind the glove box. I'm not sure what the accessibility is like with the new models though. Generally they're pretty easy to get to.
  • 2011 slx crdi
Lot easier to access with the gd.
The glovebox is "dropped" by removing twist plug rather than one which requires you to "force" out with flat head screwy
Offline msoon
Thanks guys. I'll try
Offline Dogsbody
      Railton, Tasmania
I had the same problem  with our VX Berlina.  It was a bacteria problem caused by moisture on the heat exchanger fins.  It is more common these days due to the compact size of the units, they tend to stay wet for a long time after they thaw out (vehicle stopped).  I was told to use pure teatree oil and spray it into the ac air intake.  It worked reasonably well.  Killed off the smell for about 12 months.  If possible, turn off the ac 5 minutes from stopping.  That helps dry out the heat exchanger with fresh air.  HTH.
  • MY14 i30 Elite CRDi Auto, white
Offline msoon
Thanks for that teatree oil tip. How much did you spray in?
Offline Dogsbody
      Railton, Tasmania
I used a 10 ml bottle of Thursday Island Tea Tree Oil.  Dispensed it from an old Brut aftershave spray bottle (very fine mist).  Turn the fan on to maximum speed with the ac off and the heat exchanger dry.  The interior will smell a bit for a while, just leave the doors open to air out. Not an unpleasant smell though.  Buy the oil from a chemist shop, it needs to be the 100% purestuff.  Let us know how it goes.
Offline msoon
Thanks!
The oil is a natural antiseptic. However, remember that it IS an oil and should any come in contact with the fins, it will adhere itself and reduce the cooling efficiency a little, so don't use too much.
